M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > BMW M5 (F10) General Forum
      06-07-2020, 02:27 PM   #1
aous101
Drives: BMW M5 F10
Question M5 f10 idle RPM issue- video attached
Hi guys,
I have been noticing a slight movement with my RPM at idle when car is warm and AC is on. There is slight vibration that comes and go as well when the RPM moves. It can be barely felt via the seats. Maybe I'm being paranoid after all, not sure . Here is a video for the movement I'm talking about.
Do you think it's normal? If not, what can be possibly wrong.
Any suggestions are welcomed.
P.s car is stock with cat back FI exhust and has 90,000 km on. No errors found using ODB2 scanner. Spark plugs were changed 3 months ago. Injector along with throttle body were cleaned as well. Replaced 2 MAF Sensors, along with OEM alternator which died a month ago.
      06-08-2020, 06:56 PM   #2
SapphireM5
SapphireM5's Avatar
711
Drives: 2013 M5 Sapphire Black
Could just be the ac compressor engaging, nothing to worry about. If you shut the ac off does it not do it? If it stops w the ac off I wouldnt worry about it. Either way seems like nothing to be concerned about.
'13 Black Sapphire Metallic - BPM Stage 1 Tune - RPI Exhaust - KW HAS Kit - 12mm spacers all around- Carbon Fiber front lip - High Kick Trunk Spoiler - Rear Roof Spoiler - IND Kidney and Fender Grills - 20% Tint all around 50% Front Windshield - PPF
      06-09-2020, 01:00 PM   #3
mundo74
65
Drives: F10M5
Paranoid. Mine gets 10 time worse sometimes, fluctuating 300 RPM. Luckily it only does it rarely.
More power please
      06-09-2020, 02:22 PM   #4
Noggie
Noggie's Avatar
Norway
285
Drives: E31 850i,i3s
This was my thought exactly.
      06-09-2020, 03:08 PM   #5
PoolCar
17
Drives: F10M5, 997 - 911
Originally Posted by aous101 View Post
Hi guys,
I honestly saw nothing!
      06-09-2020, 03:24 PM   #6
aous101
Drives: BMW M5 F10
Thank you all for the feedback. When I turn the ac off, it stabilise and the slight vibration goes away.
I guess I need to take it easy on my OCD
      06-09-2020, 04:48 PM   #7
SapphireM5
SapphireM5's Avatar
711
I am very OCD so I get it, but that's nothing to even consider an issue.
      06-16-2020, 11:11 PM   #8
q94f10
Drives: retired: 2015 M6 GC
My 2015 m6 gc would do that also. Indy shop couldn't find anything wrong with it. I did recently install the bms intakes and it made it worst, but only during startup, esp when the car has been sitting in the sun for a while. Once its moving and comes to a stop the rpm barely fluctuate. I think these cars are very sensitive to temp of air going into intakes and that causes MAF sensor to fluctuate the rpm based on air density.
      06-17-2020, 03:31 AM   #9
Craze
161
Drives: M5 E60, M5 F10, X5 50i
Seems normal
2 s63 motors in the house and both similar
      06-17-2020, 11:04 AM   #10
Noggie
Noggie's Avatar
Norway
285
Funny story.
A friend of mine pulled a trick on me many years ago when I had an E36 sedan.
He was in the back seat, and when he pushed the button to close the rear door window, which was closed, the car would do a small rpm drop.
He then got my attention to this and kept pressing the button at various intervals while we were waiting for another passenger.
He borderline got me to think that there was an issue with the car before laughing and telling me what he did.
      06-17-2020, 12:19 PM   #11
S_CDSM5
42
Drives: 650 Gran Coupe
Mine certainly has this very slight RPM fluctuation but only notice it when first starting it up once the high idle is done. Once its warm i notice nothing
      02-21-2021, 08:28 PM   #12
Aceway
Drives: E82 135i / F25 28i
Fixed my rpm fluctuation issue. Rpm would fluctuate at idle even when fully warmed up with a considerable amount of driving time. Initially I cleaned my MAF sensors which did not make a difference. I order a new pair of MAF sensors and O2 sensors. Fixed my issue, I'm going to guess it was O2 sensors but who knows now. My car is at 73k miles, problem popped up pretty recently.
Honestly I'm so happy it wasn't injectors although I'm sure that's in my future. Not even mad that I dropped one of bolts to the brace above the o2 sensors.
Tags
rpm fluctuations
