M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > BMW M5 (F10) General Forum
      05-28-2020, 09:18 AM   #1
Noggie
Noggie's Avatar
Norway
285
Drives: E31 850i,i3s
ticking sound from front
Guys, just want to hear if anyone else has this.
I just started hearing a ticking sound from the front of the car, it may have been there for a while, it may be completely normal. Spring is here and I had the windows rolled down and that's when I heard it.
It sounds just like when you have a small rock caught in the thread of your tire, changes with speed, and I was sure that was what it was.
But no, checked all 4 tires, no rocks.
Ticking sound is still there, seems to be on the side you load as well, turn right and it ticks from the right side, turn left and it ticks from the left, drive completely straight and it's quiet.
I did think it could be the brakes, after all floating rotors do make a bit of sound, but, applying a slight braking force will not make the sound disappear, and I have the ceramic brakes and those don't seem to be floating in the same manner the steel ones are.
Cant find anything loose and I can't really find any plausible explanation for the sound.
-14 M5 competition pack w/ceramic brakes, bone stock suspension and wheels.
Anyone have/had anything similar?
      05-28-2020, 10:32 AM   #2
OneExtra
OneExtra's Avatar
United Kingdom
811
Drives: None
small stone caught between the disc and disc guard maybe
      05-28-2020, 11:05 AM   #3
Noggie
Noggie's Avatar
Norway
285
It doesn't make that horrible sound that makes, this sounds just like a small stone or screw stuck in your tire. since the frequency changes with speed, it acts the same as well.
I'll teke the car out tonight on some quiet side roads and see if I can figure out some more, do some proper braking and see if the brakes are to blame after all, sticking brake pads or something.
Edit:
Been out really given the brakes a workout, at one time the active protection system kicked in and tightened my seatbelt
Not much change, if any, still have a ticking on the outside front tire when turning.
I checked my wheel bolts, and I guess they could have been tighter, I tightened all of them from 1/8 to 1/4 turn.
Guess I'll have to see next time if that made a difference, if not I need to take the wheels off and do some sort of inspection.
      05-29-2020, 10:38 AM   #4
Noggie
Noggie's Avatar
Norway
285
Well, tightening the wheel bolts seems to have done the trick.
All is quiet now.
I did not expect that 1/8 to 1/4 turn was to blame.
When I changed tires a month ago, I did them up with an impact gun and a 110nm/81ft lbs torque pin.
Note to self: Torque the bolts by hand next time.
      05-29-2020, 12:30 PM   #5
Dwaynos
Dwaynos's Avatar
United Kingdom
380
Drives: F10 M5 Monte Carlo Blue
All is quiet now.
Torque on the M5 wheels should be 140nm.
      05-29-2020, 01:02 PM   #6
SCD-1983
SCD-1983's Avatar
576
Drives: 2014 F10 M5 Frozen Blue
All is quiet now.
Correct, 110 Nm is not enough for the F10 lug bolts. And an impact wrench cannot even come close to the precision of a torque wrench. I always tighten the bolts with 140 Nm, then drive about 50 kilometers and re-tighten them again. Never had an issue!
      05-29-2020, 03:50 PM   #7
Noggie
Noggie's Avatar
Norway
285
You guys are probably right.
I use 110nm on my older BMW, but they have M12 bolts, the M5 has M14 bolts so it makes sense the torque is higher, 140 seems right.
I normally do them up with the impact gun with the toque and then with a wrench, but this time I forgot to use the wrench.
This is also the first time I have had a "lose wheel" in 25 years of driving.
