      05-19-2020, 04:27 AM   #1
golfer23rm
golfer23rm's Avatar
South Africa
45
Drives: 2010 BMW 125i E82 Bluewater
125i - 18in square or not?
good day addicts....
i need help, i plan to get a set of wheels but dont know what.
i want to keep it OEM.
so the styles i was thinking are:
Style 162 - E90 18s. think there might be rear issues.
Stlye 216 - if i can find
Stlye 264 - if i can find
Stlye 261 - can find, but M badges and my car has no M stuff.
these are all narrows and wides.
i was wondering since i have 17s 225s all round, is there an oem 18 in a square set up i could look at that would look good and work on my car?
thanks.
      05-19-2020, 04:44 AM   #2
FredrikM
FredrikM's Avatar
Sweden
45
Drives: Jet Black 125iC (272 HP)
My car was delivered with Star Spoke 264.
Front 71/2JX18 ET:49
Rear 81/2JX18 ET:52
I have always had staggered setups on my BMW's and i really think you should go for staggered, not square.
Mods: Black kidneys & side markers, blackline rear lights, 2008 side mirrors, 19" VMR 701, remapped, 135i instrument cluster, X3 Steering wheel trim, Z4M gear knob
      05-19-2020, 05:42 AM   #3
golfer23rm
golfer23rm's Avatar
South Africa
45
hi thanks for the reply.
love that wheel on the 1er.
reason for thinking square was being able to rotate.
otherwise maybe it will help with the stance and look of the car if i go narrows & wides.
      05-19-2020, 05:51 AM   #4
golfer23rm
golfer23rm's Avatar
South Africa
45
Rear 81/2JX18 ET:52
whats the spec on the tires?
      05-19-2020, 06:51 AM   #5
FredrikM
FredrikM's Avatar
Sweden
45
215/40 R18 and 245/35 R18
      05-20-2020, 04:18 AM   #6
golfer23rm
golfer23rm's Avatar
South Africa
45
i think i want to do this.....
what issues will i be looking at?
BMW Style 397
8X18" ET34
Front:215/35/18
Rear: 255/35/18
i can get these tires on:
235/35/18 front & 255/35/18 rear.
will there be an issues?
      05-20-2020, 07:43 AM   #7
FredrikM
FredrikM's Avatar
Sweden
45
I like this calculator for comparing rims.
I have entered my stock wheel sizes as comparison.
Front
Rear
You will have to try to measure fender clearance and add those measurements to the calculation.
I would have chosen 215/40 and 245/35 to keep the wheel diameter to 629 mm, making one less parameter to be able to cause any issues with rubbing and a speedometer not showing the correct speed.
      05-25-2020, 10:42 AM   #8
golfer23rm
golfer23rm's Avatar
South Africa
45
i found a set of bmw style 386 wheels...off the F20
should be a good fit.
what tires would work best on there? they are narrows/wides.
      05-25-2020, 03:53 PM   #9
NorthernDancer
850
Drives: 08 Sedona 128 & 06 330xiT 6MT
think the offset of these are wrong (34 or 37) whereas you want square 47 or staggered 49 and 52. Don't rush into this- do it once, do it right.
      05-25-2020, 05:45 PM   #10
Piper1
Piper1's Avatar
Drives: E85
Rear 81/2JX18 ET:52
I'd say that'd all depend on your driving style/needs. Not all bmws are staggered from factory, I've noticed the trend in factory staggering in higher trims due to higher power and certain amount of understeer tuned in from factory. I took my non M Z4 and in prep for the s/c and loads of other mods and changed my stance from 225 factory square to 255 square. If memory serves M z4 is 225 / 255 staggered. Of course a lot of other suspension bits took place as well but I'd say square vs stagger is based on ones needs.
      05-26-2020, 05:46 AM   #11
golfer23rm
golfer23rm's Avatar
South Africa
45
thanks gents...
currently on the car i have 225/45/17 in square.
so i could replace those but 18s would look nicer.
i dont do a lot of driving so narrows and wides aren't needed more than just for looks.
the car doesnt see a track.
      06-25-2020, 10:07 AM   #12
golfer23rm
golfer23rm's Avatar
South Africa
45
still doing a bit of research, but i see the Style 397 is ET34 all round.
this set up would allow me the square 18 i want and i can look at running 225/40/18.
can this work? i am coming from a 225/45/17. the car at stock E82 height. non m sport.
      06-25-2020, 04:31 PM   #13
..Rush..
..Rush..'s Avatar
Drives: AW E88
Your car?
Or someone else's?
I'd like to know more about this one as well.
BMW Style 397
8X18" ET34
Front:215/35/18
Rear: 255/35/18
      06-26-2020, 05:59 AM   #14
golfer23rm
golfer23rm's Avatar
South Africa
45
someone else.
im trying to figure out if that 397 can work. it's square.
the wheel is 8" and ET34.
reading from here says will rub:
https://www.1addicts.com/forums/showthread.php?t=749149
this says the front at ET34 can work. is there a big difference from 7.5J to 8J?
https://www.1addicts.com/forums/showthread.php?t=727712
"Life moves pretty fast. If you don't stop and look around once in a while, you could miss it...."
Ferris Bueller
