05-12-2020, 01:53 AM | #1 |
344
Rep 368
polishing machined lip
Hi, I'm trying to polish my machined lip but I'm not having any luck with mag polish and a buffing cone / drill attachment as instructed on several YouTube videos.
Polishing the lip for 20 mind didn't seem to create even a minor change in the lips reflectance. Any one here have any advice on how to get this to a mirror finish? |
05-12-2020, 08:57 AM | #2 |
mTekMods
2149
Rep 2,906
thats how machined lips are supposed to look bro
2011 Frozen Black/Fox Red E90 M3 650+WHP
G-Power Supercharged First DCT to Manual Conversion Worldwide KW CS, BBS RI-A, BW Headers, Snow 2.5 |
05-12-2020, 10:20 AM | #3 |
183
Rep 305
What he said. If you want a polished finish on your machine flips, you're gonna need something stronger than white diamonds. We use that shit on 18k gold, which is WAY softer than your rims.
But again, you would be altering the factory finish so ymmv. |
05-12-2020, 12:05 PM | #4 |
1341
Rep 1,881
machined lips typically have a clear coat on them as well. yer gonna have to do a multi-step sanding/polishing to get any kind of results.
I am never able to post pictures on forums, all my pics are on IG @baye30 https://www.instagram.com/baye30/
Current Garage - [2011 E90 M3 ZCP] [2005 E53 X5 3.0 Sport] [1988 E30 325IS 24V] |
05-12-2020, 12:33 PM | #5 |
Save the manuals!
6020
Rep 6,751
What wheels are they? The lips seem to be clearcoated. If you want that crazy almost chrome shine, you need to sand the clear coat off and polish the aluminum.
I had mine stripped, sanded, and polished. Then ceramic coated to reduce the upkeep required on the bare, polished aluminum finish. Here's a pic while the ceramic coating was curing.
'16 M3 | '23 718 Spyder Past: E92 M3, F87 M2, E39 M5, etc Last edited by 6ixSpd; 05-12-2020 at 11:31 PM.. |
05-12-2020, 02:22 PM | #6 | |
344
Rep 368
Yeah, this is exactly what I was looking for - I realized I hadn't mentioned in my original post that I wanted them to have a mirror finish. How much time did that take or how much did it cost? |
05-12-2020, 07:35 PM | #8 |
Save the manuals!
6020
Rep 6,751
I wouldn't do it by hand because of how much work is required. I had them done as part of when they were being fully refinished. I think $100/wheel is the going rate. Maybe some more for disassembly and re-assembly.
'16 M3 | '23 718 Spyder Past: E92 M3, F87 M2, E39 M5, etc |
05-12-2020, 08:59 PM | #9 | |
344
Rep 368
My wheel guy seems to be a bit gun shy about taking 2 piece bbs apart. I think this will be my last 2 piece wheel. A royal pain in the ass. |
05-12-2020, 09:49 PM | #10 |
Save the manuals!
6020
Rep 6,751
Aren't you in Cali? There should easily be a wheel refinishing place that can handle 2pc wheels. Sounds like you need a new guy
Yeah there's quite a few pics over these boards. Check my past threads on this forum or my IG @tailor.mad3
05-12-2020, 11:35 PM | #11 | |
344
Rep 368
I'll check out the regional forum and see if folks have better recommendations. |
05-14-2020, 03:49 PM | #12 |
F15 daddymobile
2352
Rep 3,512
Those are clearcoated. You'll need to separate the faces from the barrels, strip the clearcoat and sand the lips... then follow up with several polish passes to make shine. Using the meguirs powerball isn't going to cut it for what you're after.
05-15-2020, 08:02 PM | #13 | |
252
Rep 631
Drives: 2014 M6 Grand Coupe CP
F06 M6 Grand Coupe CP
Sapphire Black Metallic The drive is the destination |
05-19-2020, 08:54 PM | #14 | |||||
344
Rep 368
Yeah, I'm going to have to redo the barrels thinking I might as well take advantage of that and redo the front barrel lengths and get a square setup of 19x9.5 all around. |
