04-13-2020, 06:52 PM | #1 |
Rep 40
Help - Big Problem !!
I purchased a 2011 X5 50i with the N63 motor exactly 3 years ago.
It had 60K on it then, has 90K on her now. On the first drive (back from the dealer), I floored it. Instead of dropping down a gear or two taking off like a rocket, it sputtered and I got the dreaded "Engine Malfunction!, reduced power" light. I was peed-off !! I found a place to pull over, put her in park, turn her off, then restart. No problem, no light. I drive this car for 3 years, 30k miles never having that happen again. I raced every Mustang and Camaro I could find, what a great car !! Yesterday while running normal, I floored it, it stumbled and I got the same light. This time when I stopped and restarted it, it continued. This morning same problem, I then tried unplugging the battery for a while, hoping the modules would reset. no go After that I plugged in Carly for BMW (full version) and ran diagnostics on the engine and got this. 002B1C Misfiring, cylinder 7 (great, a generic message) I did some research, and it's highly unlikely 3 years ago a coil or plug went bad, just for a moment, when I floored it, then was fine for the next 3 years. Maybe this episode has nothing to do with the one 3 years ago, (but it's very suspicious that it happened the same, exact way, when flooring it). It didn't sloooowly go bad, it was instantaneous 3 years ago, just like now. I cleared the code, popped the hood, let the car cool down a couple hours. I just started her up and eased her out of the driveway, then eased her down the street. not even 100ft and it kicked on. Is this electrical, is something causing one of the injectors to be shut down ?? I am a single dad w/2 school kids, living paycheck to paycheck and I am screwed right now. I have lost half my pay due to covid-19 Any suggestions to diagnose it will be greatly appreciated. thank you |
04-13-2020, 07:17 PM | #2 |
The Quiet One
1713
Rep 624
Sorry for your angst at this time.
You received the car at 60 k miles but can never be sure about status of plugs/coils and when they were last changed. You now have 30 k more miles on them. You’re getting a mis-hit there so I’d start there first. Are you handy, and can change them out on your own ?
2013 M6 Coupe Sakhir Orange Metallic / Sakhir Orange \ Black Merino - The Prince
2013 X5 LCI 35i Jet Black / Black SensaTec - The Horse 2013 X5 LCI 35i Space Grey Metallic / Black Nevada // Sport Pkg - Daughter’s 2013 X6 M Sapphire Black Metallic / Black Merino \ Carbon Fiber - Son’s |
04-13-2020, 08:12 PM | #3 |
217
Rep 780
Same thing happened to me too. Start by changing the plugs/Coils (use BMW original) and if problem persists, it's the Injectors.
If you didn't have the original parts, BMW might not move to Injectors unless the plugs/coils are switched to OEM, ask me how I know? |
04-13-2020, 08:27 PM | #4 |
2022 M4 Comp Xdrive
1016
Rep 1,538
Good way to check if it's the coils is swap coil with cyl 5 or something.
Go for a drive ..if the code occurs again and goes to cyl 5, you know it's the coil. If it stays on cyl 7 u can swap the spark plug from 7 to...3? Retry. It'll be better to troubleshoot this first before spending on an injector. |
NorthCountryGuy1713.00 |
04-13-2020, 08:44 PM | #5 |
The Quiet One
1713
Rep 624
Also, I add Techron to my gas on a very regular basis on all my cars. Did so on my 32 year old Porsche for 20 years. My injectors looked brand new at the very end. I buy it in bulk.
04-13-2020, 09:03 PM | #6 |
217
Rep 780
I am sure Injectors are under warranty for 12 yrs/120,000 miles at least in an X5M, please confirm your application?
They replaced 2 on mine ('12 X5M with 42K miles) and it runs flawlessly bow. |
04-13-2020, 09:50 PM | #7 | |
Rep 40
Problem is I read this is a generic code that would even pop up if you had a 6 cyl (so it could be any cylinder) ?? https://autoservicecosts.com/obd2-codes/p0307/ (there's a million links saying this, this one is random) I am very handy, I'm just worried about cost, (especially the OEM recommendation) I don't want to replace anything I don't have to right now, (until my stimulus check arrives in May?). Is there a DIY video or a parts link anywhere that you guys know of ?? thanks again guys, if I had a free guess, it sounds like a weak coil to me, (will idle just fine, but don't have enough juice under load). |
04-13-2020, 10:19 PM | #8 |
1416
Rep 1,564
Misfire code is a right of passage for n63/S63 engines. Like other members mentioned Normally coil or sparkplug, then next is injectors. Lucky for you, changing coils and plugs on this car is as easy as it gets. Infact coils don't require anything but your finger to remove (once you get the lame air cleaners out of the way. You can do all the plugs and coils easily in a few hours.
I just got done rebuilding the top end of mine (2012 50i, 150k miles. I have extra bremi coils and bosch plugs with less then 20k on them. Private message me if interested. Otherwise go to FCP euro for best deal on new plugs and coils if you want brand new. Go with Eldor or Bremi coils, Bosch or NGK plugs. Your going to want to replace all the plugs and coils now with your mileage or get ready vfor a misfire code every other week. Trust me, I was in Exactly your position 2 years ago and have learned much since then. Amazing engine if maintained properly. Last edited by Sophisticated Redneck; 04-13-2020 at 10:24 PM.. |
04-14-2020, 10:14 AM | #9 | |
Rep 40
I would like to thank Everyone for taking the time to try and help me out. My injectors are still covered under factory warranty, will the dealer shIt if they see non-BMW coils & Plugs? Does anyone know of a good DIY video? thanks again guys |
04-14-2020, 10:53 AM | #10 |
217
Rep 780
Spend a little more and get the BMW OEM (not OE) coils/plugs or you might end up spending a lot more
Try this video: and https://www.xbimmers.com/forums/show....php?t=1400661 Also get a BMW spark plug socket, comes in really handy... |
04-14-2020, 11:06 AM | #11 | |
1416
Rep 1,564
AutoZone has a nice 14mm 12point thin-walled spark plug socket that works perfect for our engines. Get yourself a good extension with a swivel end (not universal) too as the plugs go in at a slight a angle. I can post pics if you like, I've gone through just about every combo and this is by far the best |
Autobacs1363.00 |
04-14-2020, 11:14 AM | #12 | |
1416
Rep 1,564
Are quite a few n63/S63 spark plug change videos up on YouTube. Other then variations in the upper intake/air cleaners, it's all the same wether it be a f10 m5 or a e70 50i. Here is a decent video on a f10: it's all super easy once you get the air filters out of the way (btw, good time to get new air filters too while you have them off) |
04-14-2020, 03:28 PM | #13 |
1363
Rep 757
Drives: 2019 BMW X6M
Just be mindful when you torque down the spark plugs. Make sure you got them threaded in correctly and do not over torque them.
2019 BMW X6M
2013 Lexus RX450H 2010 Nissan GTR AMS Omega 14 |
