09-14-2008, 04:28 AM | #1 |
100
Rep 1,035
I re-weighed the OEM brakes
I was moving my OEM brakes when I was able to find my Pelouze postal scale. So I figured I what the heck, why not weigh them to verify the numbers that OC kid came up with. Well, I was in for a bit of a surprise. The numbers I came up with were quite a bit less than what was previously thought.
Front caliper previously thought to be 15.2 pounds was actually 14.5 pounds with pads and OEM rubber line attached. Rear caliper previously measured at 12.1 pounds I measured it at 11 pounds with pads and OEM rubber line. Front rotor previously measured at 26.6 pounds I measured at 22.7 pounds. Rear rotor previously measured at 22.8 pounds I measured at 19.7 pounds. So then the question I had was just how accurate is the little Pelouze scale. I grabbed a 25 pound dumbbell to find out. It weighed in at exactly 25 pounds. So these numbers are pretty accurate and might make the stock brake guys happier. I believe OC kid used a bathroom scale to weigh the brakes before so that could be the reason for the difference.
09-14-2008, 11:19 AM | #2 |
Bored at work....
890
Rep 5,391
Very nice post. Thank you.
Grey Matter:2008 E92 M3:608/425. SG/PS SOLD!
Dark Matter:2015 F80 M3:495/505. SOLD! Anti Matter :2016 F82 M4 GTS What next?!? A 2022 M235i GC- I must be getting old |
10-02-2008, 07:18 PM | #5 |
100
Rep 1,035
Brembos would be lighter but I'm not sure how much. Someone should take an accurate measurement of the Brembo kit to be sure.
10-02-2008, 09:58 PM | #6 |
Veni Vidi Vici
89
Rep 2,750
Drives: '11 JB/BBe-6sp-e90
Garage List 2011 e90 M3-Sold [8.50]
2003 RS6 - Sold [0.00] 2009 e90 M3 - Gone [0.00] 2003 M3 SOLD [0.00] old 2002 [10.00] |
Mantis!
One of these days .... To da moon!
Dinan compliment of stuff plus PF rotors and RG63s. Enough for now. Why, yes. I am an abrasive bastard. |
10-02-2008, 10:26 PM | #7 |
374
Rep 8,033
What makes you think that dumbbell indeed weighs 25lbs?
Sorry I couldn't resist, but you get my drift. Also, global ban on OC Kid for using bathroom scale!?
10-04-2008, 02:00 AM | #8 |
20
Rep 298
Weight savings is just one advantage
10-14-2008, 02:23 PM | #9 |
163
Rep 436
True when the brakes get hot, when they are cold the stopping power isnt all that great. Also I have noticed noise when the brakes are cold. Have you had these problems?
Arsenal F.C. - Gooner 4 Life
10-14-2008, 07:33 PM | #10 | |
Dr. Octagon
260
Rep 1,919
My testing was never purported to be anything more than what I said it was; unofficial. I did what I could with what I had at the time, my figures were averages taken from a plain-old bathroom scale. I think I even posted pictures with the brakes on the crappy scale... lucid: You didn't have a problem with my less-than scientific scale back in May, or whenever it was, when I weighed the brakes... oh well... good-bye cruel world...
OC ///M
2013 E92 M3 Individual Sold: 2011 E92 M3 SSII | Sold: 2008 E92 M3 SSII | Into a Wall: 2008 E92 M3 SSII | Sold: 2007 E92 335i JB |
10-14-2008, 07:36 PM | #11 | |
374
Rep 8,033
Your numbers are not that off, and they served us well as a reasonable estimate. Now, please don't blow your head off man. How are those Brembo's working out for you btw?
10-15-2008, 07:41 AM | #12 |
374
Rep 8,033
Badfish, do you have accurate weight specs on the Brembo kit in your car? I want to update the numbers here with the numbers you posted on this thread:
http://www.m3post.com/forums/showthr...ngs+benchmarks But I'll stick to OC's numbers since whatever error his scale might have had is at least applies to both the stock and the Brembo systems, so the weight difference should be relatively accurate. If I use your numbers, I can't use OC's numbers for the Brembos. Thanks for taking the time weigh these things guys.
10-15-2008, 10:56 AM | #13 | ||
100
Rep 1,035
10-16-2008, 07:11 AM | #14 | |
374
Rep 8,033
10-16-2008, 01:42 PM | #15 |
8
Rep 153
Brembo performed extremely well under excessive amount of hard braking. I was very impressed with them. Take a picture of the Brembo BBK and a pic of stock brakes then compare with them side by side, you guys will know why.
