GetBMWParts
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Forum > Regional Forums > USA - Southwest
      03-21-2020, 01:44 PM   #1
///M3 Ghost
F80 ///M3 Mineral White E90 ///M3 Alpine White
///M3 Ghost's Avatar
Drives: 2017 F80 M3 Mineral White
FS: F8X Active Autowerke Midpipe w/Chassis Brace
SOLD!!!
Active Autowerke has been an industry leader in engineering high quality BMW performance products for over 30 years. Dedicated to improving performance with the highest quality products, Active Autowerke is synonymous with making power. Their philosophy is on developing refined BMW performance parts, with power in mind, and providing them to a large BMW community, which is a valuable addition to most BMW Enthusiasts.
The Active Autowerke F8X Mid Pipe was specifically designed to eliminate the highly restrictive nature of the OEM F80 M3 and F82 M4 mid pipe; therefore creating optimal exhaust flow and drastically improving performance. After much research and testing Active Autowerke discovered that synchronization of the Turbos were a major factor in generation of the current sound. The solution was a single mid pipe, which eliminated much of the annoying sound. The next challenge was making a large 3.5" single midpipe, which was needed for optimum performance, and needed to fit without ground clearance issues. This lead to the creation of the oval pipe design. Engineered for an exact fit on both the F80 M3 and F82 M4, the difference in power with this mid pipe will be noticeable the moment it is installed.
This installation does will not create any CEL codes, as only the secondary cats are removed, and are not monitored by O2 sensors. This means no tuning required. PM me if interested.
KEY FEATURES INCLUDE:
~18+ WHP over stock
~30+ LB-FT over stock
- Improved performance from less back pressure (Less restrictive, more free flowing)
- Increased low end and mid-range power
- Quicker turbo spool
- Lighter weight than factory system
- Deeper & throatier exhaust note
- Single-pipe design eliminates cheap “weed-eater” sound from factory exhaust
2017 F80 ///M3 Mineral White Metallic
2010 E90 ///M3 Alpine White
      04-08-2020, 04:29 AM   #2
F80Pilot
28
Drives: F80 M3
ship CALI?
      04-13-2020, 10:11 AM   #3
glockz
glockz's Avatar
22
Drives: 2016 M4 ZCP
Where are you located?
      04-18-2020, 03:36 PM   #4
BananaSlug
BananaSlug's Avatar
Drives: Mk7 GTI → F80 M3
It's $799 new on AutoTalent.
2017 Yas Marina Blue M3 ZCP
      05-04-2020, 08:49 AM   #5
///M3 Ghost
Bump!
      05-06-2020, 02:24 AM   #6
Treydadon
Drives: F83
800 shipped to New York
      05-11-2020, 11:22 AM   #7
///M3 Ghost
PM'd
      05-20-2020, 09:48 AM   #8
torvektheo
torvektheo's Avatar
Drives: F25 X3; 981 Cayman S
Is this midpipe still available?
f80post
