03-17-2020, 12:45 AM | #1 |
Rep 11
These just came in from Wheelfire. Mounted on Hankook Ventus V12 EVO2's. Wheel stud conversion kit should be in today. It looks like they should clear everything but there's a local shop that does fender rolling locally. Will post more pics later.
2011 135i / 2nd owner / 86K miles / all stock
2012 F250 SD Lariat 4x4-6.2L
2011 135i M Sport 6-speed (all stock for now) 2002 M3 - Sold 2007 Dyna Street Bob - Sold 1998-2001 740i M-Sport (hopefully next) |
03-17-2020, 05:53 PM | #2 |
121
Rep 2,037
Drives: 2008 135 blk, blk, step
Garage List 1994 Porsche 968 Cab [0.00]
2017 AMG GTS [0.00] 1994 Porsche 968 Coupe [0.00] 1977 Mercedes 450SE ... [0.00] 2008 135 [8.00] |
Nice. It's gonna be tighter than you think. But will look great once you get it worked out.
Injen, RR OCC, MadDad Whisper, donut spare, 19x8.5et43fr 19x9.5et45r Volk LE37's, rear fenders rolled/pulled, PSS4S 225/35fr 255/30r, KW V1's, AR coated catless dps, Cross strutbar, CF grills and license plate holder, iCarbon diffuser, ETS black anodized FMIC, M3 control arms, Quaife, ER chargepipe, ForgeDV's, Topspeed Custom Tune, V3sims, Braille, Andrey_GTA rear hub mod, Ebay Mstyle front bumper and performance style side skirts.
b1aze565.50 |
03-18-2020, 05:46 PM | #3 |
Rep 11
Thanks. It looks like it may be tight too... but I should be able to avoid a fender roll. I'll definitely post pics when I get to that point. I thought I'd be there today haha!
Today I had an issue with getting the lugs seated. It appears they're too wide for the wheel holes. Any ideas what to do here? A longer stud bolt... or a different type of lug, like something more narrow? See the pics below. Not sure the best way to go with this. Forgot to add this earlier: *Front tires: 225/40/18 *Rear Tires: 255/35/18
03-19-2020, 01:36 PM | #4 |
Rep 11
Thanks to the guys @ Wheelfire for hooking me up with the tuner lugs. Perfect fit.
I was able to get the wheels on. They fit, as Wheelfire promised with any rubbing or scraping. I've only driven around the block, top speed about 45, so I may need to go over more bumps and turns to see. The air pressure isn't correct yet either. Once I get some air in them and drive on them for a few days I'll report back. More pics below. There's definitely some poke in the rear. Still no rub.
03-19-2020, 06:32 PM | #6 |
Rep 11
I did get a few rubs on hard bumps at higher speeds in the front.. and a rub in the front when going "faster" over parking lot speed bumps.
Overall... HUGE difference. I can only imagine how the MPS4's feel. Much softer ride.. the run-flats were just to harsh for DC/MD streets. The have way more give.. and just enough without feeling sloshy. Grip is incredibly better.. the car is a lot more planted and rolls with way better ease. Noise level is like night and day. No more road noise cruising @ 35-50 mph. Changing the tires and wheel out these were a lot lighter. I'm sure this contributes to the overall feel too. Definitely glad I went with these!
03-19-2020, 06:38 PM | #7 |
Rep 11
Side marker swap
04-22-2024, 03:32 PM | #8 | |
Rep 32
Are you on stock m performance suspension? |
