03-05-2020, 02:12 PM | #1 |
Big Cat Rescue
53
Rep 215
F82 Mirror Tap (Colors for 12v and Ground)
Hey DIYers -
Does anyone know on the top of their head the colors for 12v and ground for the rear view mirror? Just purchased a blendmount for a Uniden R7 on a 2020 M4CS. I'd like to do this myself instead of going to best buy - any suggestions / help please? Cheers |
03-05-2020, 03:27 PM | #2 | |
36
Rep 86
CaroleBaskin53.00 |
03-05-2020, 03:46 PM | #3 |
1234
Rep 1,164
The 2 wires are...
Solid Brown Green w/ brown strip Forgot which is ground... think its solid brown. |
CaroleBaskin53.00 |
03-05-2020, 08:48 PM | #4 |
252
Rep 631
Drives: 2014 M6 Grand Coupe CP
brown is ground.
F06 M6 Grand Coupe CP
Sapphire Black Metallic The drive is the destination |
CaroleBaskin53.00 |
03-05-2020, 09:00 PM | #5 | |
Big Cat Rescue
53
Rep 215
2020 M4CS - Lime Rock Grey
03-06-2020, 09:49 AM | #7 |
1234
Rep 1,164
Nicely done. Can always appreciate a clean install.
CaroleBaskin53.00 |
03-08-2020, 08:11 AM | #9 |
31
Rep 185
Hi, just got my r7, could you link me the the blendmount you used? Also, did you find any install videos/tips/write ups that were helpfull. thanks, also, did you/plan to install a dashcam as well?
03-10-2020, 11:11 AM | #10 |
Big Cat Rescue
53
Rep 215
100% useful - it's great for those cops running KA on the other side of the road so it points at them coming and then arrow back for leaving
03-10-2020, 11:13 AM | #11 | |
Big Cat Rescue
53
Rep 215
It's simple bud, you don't need a write up but I'll give you one: - using a pry tool split the protective cover open behind the rear view mirror - install the mirror tap (green/brown=12v brown=ground) assuming you're in a f8x - zip tie it so it does not wiggle out - install the cover back - install blend mount Products Used: https://blendmount.com/power-cord-mt...525-lg-mt-4015 https://blendmount.com/aluminum-rada...y-2017-series/
GA///BIT31.00 |
03-13-2020, 10:03 PM | #12 |
31
Rep 185
Thanks for the info. Another question, how did you go about installing your dashcam? Did you use a mirror tap, hardwired/ or external battery route?
03-14-2020, 03:12 PM | #13 |
252
Rep 631
Ran the power wire down the right side A pillar and the 12 to 5 V supply is installed behind the glove box.
03-14-2020, 03:57 PM | #14 |
Big Cat Rescue
53
Rep 215
The power is going to the fuse box in the rear of the car with a magic pro for parking mode!
