02-18-2020, 12:11 PM | #1 |
Rep 5
Fitment help please? Custom wheel build.
Hi guys new to the forum and new 135i owner. I am looking to outfit my car with a set of custom forged wheels. Haven’t decided on monoblock, 2pc, 3pc or any specific details to the concave / convex shape of them.
If it’s not a matter of limits to the customizability of a wheel what would be the ideal size of an 18” wheel that will both fit a stock suspension and BMW Performance or Ohlins Road and Track setup without rubbing in any way. I know this depends on quite a bit of things but I have the opportunity to get a set built and need some help. I’m totally up got changing directions whether it be flat face, deep, lip, welded. Any positive suggestions or advice would be helpful. Thanks. |
02-18-2020, 01:09 PM | #3 |
YNWA
1043
Rep 813
You'd need to know wheel widths before you can decide on offsets. You may even need to know which exact tires first, if you wanted super flush fitment.
A good place to start is the standard widths/offsets for Apex like Mighty mentioned ^. 18x8.5" et 45 iirc. Seems like the front can handle a lower offset than the rear, where there's more room inboard. You going custom could really take advantage of that. Perhaps something like et40 front and et50 rear?
/// 2004 Silvergrey M3 · Coupe · 6MT · Slicktop · zero options
/// 2011 Jerez/Bamboo E90 M3 · DCT · Slicktop · IG: @na.s54 |
02-18-2020, 02:03 PM | #4 |
1Addict
3234
Rep 7,894
What size tires do you want to run? Are these all purpose, just for show, track, DD only, etc.
02-18-2020, 06:30 PM | #5 |
121
Rep 2,037
Drives: 2008 135 blk, blk, step
Garage List 1994 Porsche 968 Cab [0.00]
2017 AMG GTS [0.00] 1994 Porsche 968 Coupe [0.00] 1977 Mercedes 450SE ... [0.00] 2008 135 [8.00] |
Yep, depends a little on what you plan to do with your car. Also a lower offset will often allow more of a concave look so that can be a factor. But for me if I were getting custom wheels I'd go 18x8.5et42 front, 18x9.5et 52rear.
Injen, RR OCC, MadDad Whisper, donut spare, 19x8.5et43fr 19x9.5et45r Volk LE37's, rear fenders rolled/pulled, PSS4S 225/35fr 255/30r, KW V1's, AR coated catless dps, Cross strutbar, CF grills and license plate holder, iCarbon diffuser, ETS black anodized FMIC, M3 control arms, Quaife, ER chargepipe, ForgeDV's, Topspeed Custom Tune, V3sims, Braille, Andrey_GTA rear hub mod, Ebay Mstyle front bumper and performance style side skirts.
02-19-2020, 02:43 PM | #6 |
No Cop No Stop
68
Rep 160
Why that offset vs what you have on your car now?
Current Garage!
2012 BMW 135i - 6MT w/ OEM 550i clutch & MFactory LWFW, Pure Stage 1, MFactory LSD, VRSF Catless Downpipe, JB4 w/ MHD BEF |
02-19-2020, 07:09 PM | #7 |
1Addict
3234
Rep 7,894
Hm. Tough.
For maximum tire is probably go for something like 18x9et42 and 18x10et55. Then run 255 front and 275/35 or 285/30 rear tire. Would need a heavy fender roll and pull with trimming and probably around 2-2.5 degrees negative camber. I know some folks who have done that can weigh in here.
02-19-2020, 07:51 PM | #8 |
Rep 5
02-20-2020, 07:12 AM | #9 |
1Addict
3234
Rep 7,894
If you can do 9.5+ and higher than et40 on 2/3pc then definitely the answer is yes.
02-20-2020, 10:30 AM | #10 |
121
Rep 2,037
If you want a square setup front to rear, et40 is OK, otherwise you'll want a higher rear offset.
MN Bimmer, I basically do have et52 rears since I did the rear brake hub mod and so that added 7-8mm to my et45 rears.
02-26-2020, 07:01 PM | #11 |
3528
Rep 6,752
Thanks to everyone who mentioned us! Here is a direct link to our guide which should have some good info on offsets and tire sizing.
https://support.apexraceparts.com/hc...-Fitment-Guide Good luck with the custom wheels! -Tom
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers |
