      02-13-2020, 12:32 PM   #1
dtla1
dtla1's Avatar
828
Drives: 2011 135i, Space Grey
Apex Arc-8, RE-71R, TC-Kline Fitment
Quick PSA, 255/35/18 Bridgestone RE-71R on Apex Arc-8 standard staggered front wheel fitment for 1 series, with TC Kline coilovers, rub a tiny bit as seen on the following pictures. Also included is a picture of the car showing ride height. Other front suspension mods include M control Arms and Hotchkiss front sway bar. About 2.3* camber.
BTW, 2x 255/35/18 Bridgestone RE-71R tires for sale, used for only 300 street miles.
lab_rat394.50
      02-13-2020, 02:08 PM   #2
TboneS54
YNWA
TboneS54's Avatar
Drives: 2004 M3 6spd & 2011 M3 DCT
Good info. Are you able to add a 3mm spacer without kissing the fender?
/// 2004 Silvergrey M3 · Coupe · 6MT · Slicktop · zero options
/// 2011 Jerez/Bamboo E90 M3 · DCT · Slicktop · IG: @na.s54
      02-13-2020, 02:12 PM   #3
dtla1
dtla1's Avatar
828
Maybe, it was already pretty tight, but 3mm isn't too much. Unfortunately I don't have any spacers that size. I think 3mm spacer, with a little bit of a fender pull might be fine.
I think my fenders have a mild pull to them, and they've been brought out the max space from the engine bay out that those bolt holes up top will allow.
      02-13-2020, 02:13 PM   #4
ShocknAwe
1Addict
ShocknAwe's Avatar
3234
Drives: E82 Mutt, M57 Truck
Nooo. Did you try spacing it 1-3mm more? Bet 255 square was awesome on re71r
2010 135i 6MT Jet Black
N54/3 FE82 Mutt | BUILD THREAD | GARAGE SALE
      02-13-2020, 05:27 PM   #5
dtla1
dtla1's Avatar
828
I didn't try any spacers on the front. But do note that the darker (cleaner) area on the fender liner is also some rubbing. Rears are actually some old 265(I think)/35/18 Hankook RS3s. I'm going to swap them all out for a set of PS4S (might try rears 275/35 which is 0.2" wider than the 265 Hankook) and I'll try some spacers then. I also need to get my front wheels checked for bends. Hard sidewalls and big potholes don't feel too good.
      02-13-2020, 07:08 PM   #6
ShocknAwe
1Addict
ShocknAwe's Avatar
3234
You'll like the ps4s. Not as good as the 71r in the dry. But an excellent all around tire. Leagues better than the PSS.
      02-14-2020, 10:18 AM   #7
dtla1
dtla1's Avatar
828
Yeah I have PS4S on style 261Ms 255/35/18 square.
      02-14-2020, 07:08 PM   #8
Ifranklin
Drives: 2008 bmw 135i
just to clarify are you on 18x8.5 +45 for fronts?
      02-14-2020, 07:10 PM   #9
dtla1
dtla1's Avatar
828
That's correct. To be fair, according to Apex's website the recommended tire is 235/40/18
      02-17-2020, 04:30 PM   #10
Expert@ApexWheels
Expert@ApexWheels's Avatar
3530
Drives: M3
So close! We generally recommend a 5mm spacer for 255/35 tires on this setup, but as others have said you might be able to get away with a 3mm judging from these photos.
The wheels look great though!
-Tom
dtla1827.50
      02-17-2020, 04:45 PM   #11
dtla1
dtla1's Avatar
828
-Tom
Thanks for the reminder on that recommendation!
