Pandora Car Alarm System
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Cosmetic and Lighting Modifications
      02-11-2020, 10:29 AM   #1
Ethan2232
Ethan2232's Avatar
Drives: BMW M4
M3 vs M4 side skirts
So I'm hearing that on an M3 you need to cut the side skirts for the jack points, is this true as well for the M4? I saw Tommy L's video of his M3 and him doing it but haven't seen an M4 install them and talk about cutting. So do I need to cut the side skirts for my M4 for the jack points?
      02-11-2020, 11:09 AM   #2
f80er
2056
Drives: An M3
The reason you don't have to do it for an M4 is because they are made for M4s and not M3s.
      02-11-2020, 04:12 PM   #3
Ethan2232
Ethan2232's Avatar
Drives: BMW M4
Thank you
      02-13-2020, 02:43 AM   #4
har-vey
United Kingdom
Drives: BMW M3 F80
Are the m3 & m4 side skirts the same length?
      02-13-2020, 06:47 PM   #5
Taco_Bueno
Taco_Bueno's Avatar
Drives: BSM BMW M4 F82
No they're like 3/4" shorter
      02-17-2020, 10:52 AM   #6
mike@x-ph.com
BimmerPost Supporting Vendor
mike@x-ph.com's Avatar
Drives: 07-335/12-328/18-M4/21-M4CP
We offer M4 side skirts, direct fit. No modifications required.
https://x-ph.com/sale/
Phone number 702-494-9435
      09-17-2020, 09:34 AM   #7
CYANiDE
Dominican Republic
167
Drives: X5 4.0i M Sport
Which skirts are shorter? The M3 or the M4 skirts?
      09-17-2020, 11:32 AM   #8
Falcigs
171
Drives: Mint Green G80 M3
I ordered your set, and they aren't a direct fit. They need to be modified to fit properly on my M3. Otherwise they stick out about an inch or more on each side....
      09-18-2020, 11:11 AM   #9
mike@x-ph.com
M3 and M4 have different specs. one size cannot be a perfect match for both models (but its not noticeable in my opinion)
its normal for it to be slightly out on the M3
      09-18-2020, 02:35 PM   #10
espressoo
899
Drives: '18 M3 Comp|'23 X5 45e|'24 X7
I have OEM M Performance rocker panel blades on my M3. They are designed for the M4 and like others have said there's a slight difference in rocker panel length between the sedan and coupe. The mounting holes does not line up either on the M3. Once installed though, unless you were down on your knees staring at it you won't notice the difference. It's maybe 1/4" gap from the edge of the blade to your wheel arches. You do have to cut around your jack points for install but it's not difficult. If you get aftermarket blades they might be specific to an M3 but some don't come pre-drilled either. Self tapping screws every ~foot is all you need.
      09-18-2020, 04:17 PM   #11
AlterZgo
1538
Drives: 23 X3 M40i, 21 911S, 24 Taycan
The M3 needs side skirts that are about 1/4” longer than the stock M4 side skirts. But the reality is, this difference is so minor I don’t notice it at all once I installed the M4 skirts on my M3. If I squat down and stare at my side skirts front and rear I will see they are about 1/8” short on both ends from being 100% flush.
      09-18-2020, 08:51 PM   #12
Tommy L Garage
2516
Drives: 2017 YMB M3 6MT CP EP VP
Oem m4 M4 skirts Are the same length as the M3 side skirt. They fit perfectly with minor cuts.
Starts at 3:52
Appreciate 2
MFNATIK3498.00
NWH8318.00
      09-18-2020, 09:53 PM   #13
MFNATIK
Blocked from G80/G82 for having an opinion
MFNATIK's Avatar
Drives: Trek Domane
Would the F30 M Performance side skirt extension work better than the M4 version? Anyone run those instead? I'm curious what the difference is?
      10-07-2020, 10:21 PM   #14
THEROK
South Korea
1268
Drives: Genesis GV80
So on the M4, BMW instructs you to drill into the body of the car to install these factory accessory skirts?
Dry sump flat six
      10-07-2020, 10:25 PM   #15
Ethan2232
Ethan2232's Avatar
Drives: BMW M4
I took off the side skirts and did nuts and bolts
      10-08-2020, 03:04 AM   #16
AlterZgo
1538
The F30 performance skirts are cut straight and don't flare out like on the M3 and M4. Therefore, they will barely be visible and won't look right on an M3.
Get the M4 skirts. Their contour is almost the same as the M3's side sills and looks much better than if you used F30 side blades.
MFNATIK3498.00
      12-08-2020, 09:29 PM   #17
AustinGelbM4
AustinGelbM4's Avatar
196
Drives: Austin Yellow M4
Those three screws, do I HAVE to drill additional holes for them to hold the side skirt?
2016 F82 M4
Austin Yellow | DCT| LED| HUD| CCB| CF Roof| Surround View
Done:Gloss Black diffuser| CP Exhaust Tips| Black Front Grills|Eibach Pro|10mm|666M
      12-08-2020, 09:49 PM   #18
BzsBimmer
BzsBimmer's Avatar
3274
Drives: '23 G80 FO M3, M3 & MY Tezzy's
I’ve got the xph cf side skirts on my M3 after removing a set of iND modified M4 factory black side skirts.
- Yes they are a tad shorter but after you install them, you really won’t notice
- you will need to drill into the xph ones. There are no holes to use. Make your own about 4-6” apart with VHB tape
- I also pinged Mike in a panic because these do not fit like the OEM modified sets because there is no cutout. I at first thought they were not going to fit but in reality, they will not sit in the same location as the OEM units. These will stick out further, assuming you used the same end points as reference.
- due to point above, you will need to be cognizant of where you place this in relationship to your plastic jack points. Not too close where it butts up against, but slightly offset.
- I use a QuickJack system and I just need to make sure the jack pad doesn’t hit the skirt.
I like the more aggressive look with how far they stick out. I always thought the OEM was too far in. You’re not going to find a factory CF skirt for F8X and I thought these were a bargain considering how much the other units sell for.
      12-09-2020, 01:53 AM   #19
JagR2611
Drives: BMW F80
I have side skirts installed on my F80 and this is/was never an issue.
      12-14-2020, 12:28 PM   #20
nbennettksu
1397
Drives: DV F80
M4 are a tad shorter.
Originally Posted by JBasham View Post
Caddy ATS . . . finally, a decent rental car option.
Originally Posted by kchu221 View Post
the wheels make me mad...
Originally Posted by mhabs View Post
It's one thing for some buffoon to put an M badge on something that doesn't deserve it...it's another for a multi-billion dollar corporation to do the exact same thing and keep a straight face.
      12-14-2020, 01:42 PM   #21
Falcigs
171
I had the same issue.
f80post
