BMW X5 and X6 Forum 2014-Current
      02-01-2020, 11:17 AM   #1
WERND
WERND's Avatar
77
Drives: E92
I'm curious what the widest tire someone is running in the rear and how much room there was with it
I'm looking at the 355 Michelin PS4
      02-01-2020, 12:02 PM   #2
jiggz
Drives: E90 M3|F15 X5 50i
I'm curious too, not that I'd run anything wider than a 325 on OEM 21's.
The 355/25/21 4S are $890 each at Discount
      02-01-2020, 02:11 PM   #3
F85MTuNED
IG: @88jae88
F85MTuNED's Avatar
1621
Drives: ///Ⓜ️
I've seen up to 335 in the rear but I'm sure it could take more.
IM POOR..
      02-01-2020, 02:39 PM   #4
1badttx5m
158
Drives: BMW m4 x5m
Funny this popped up, if my friend still has his tires from his gtr I will try and put them on my wheels. The front would have to be 295-30-21. I literally looked this up the other day.
      02-01-2020, 03:10 PM   #5
1badttx5m
158
Drives: BMW m4 x5m
It might not look right as far as tire height goes unless it’s really lowered
      02-01-2020, 03:38 PM   #6
WERND
WERND's Avatar
77
Drives: E92
Once again I don't ask the full question, my bad.
I'm going to get custom rims 21x13 in the rear and I really want the 355 in the rear, I'm just curios what others have fit in the rear with aftermarket rims that are wider than stock.
      02-01-2020, 03:43 PM   #7
gqgambler
gqgambler's Avatar
Drives: Fast & Furious
I would suggest the question being posed is inaccurate and should be either one of the follow:
1. What is the widest tires someone is running on OEM spec size rims?
2. What is the widest tires someone is running on non-standard rims?
As our rides do not have 4 wheel steering there really is no limit on width if you are on non-standard rims. Aside from visual appearance and height restriction to prevent rubbing there would be no limitation to width with the right rim. If you are using a standard spec rim then you are limited to what size tires can safely be mounted on the 21's rim which has a 11.5" width.
No. Try not. Do. Or do not. There is no try.
-Yoda
      02-01-2020, 03:44 PM   #8
gqgambler
gqgambler's Avatar
Ah, see above...we must have been typing at the same time
-Yoda
xbimmers
