01-23-2020, 04:14 PM | #1 |
IG: @88jae88
1621
Rep 1,734
Feeler.. Special order Future classic spacers for X5M / X6M
So I've looking at all the best options for spacers on this particular platform and I found some good stuff but personally I've never been a fan of spacers I always liked my rims to be direct with the hub. Nowadays things are different most companies are making hub centric setups and that makes everything even better but in my opinion FC / IND took it a step further...
Beautiful setup right? Well 1 problem fellas they don't make this sick setup for our vehicles plus their hasn't been a demand for it so we wouldn't be able to get them until now! After speaking with IND / FC they are willing to produce a small run. The design will need to be new as the hub bore is wider, tools with the machine shop will need to be revised etc. Overall the minimum order quantity will likely be around 20-25 sets so we're looking at roughly 10-15 cars but I think we can make something happen with a 10 car minimum. Future classic will not have more information on pricing until some details are worked out with their machine shop. I was told for a limited run a non refundable deposit will need to be taken for each set. So moral of the story is I made this long ass thread to see if any of you want these as bad as I do (they'll be perfect with my wheel stud conversion ) and are willing to take this small step so we can acquire a really nice item. I already got a verbal from 1 local guy so that's 2 counting myself, anybody else interested?
IM POOR..
01-23-2020, 09:22 PM | #5 | |
791
Rep 1,179
Drives: 2014 X5 50i M Sport, M3(sold)
01-23-2020, 11:16 PM | #7 | |
791
Rep 1,179
01-24-2020, 09:24 AM | #8 |
IG: @88jae88
1621
Rep 1,734
Always did... remember RR is bimmer but now they have them for most of the new bimmers now. I actually have them on my F85.
IM POOR..
skoold2003791.00 |
01-24-2020, 08:28 PM | #10 |
IG: @88jae88
1621
Rep 1,734
Bump fellas... really looking to make this happen once we have at least 10 members interested we can actually pull the trigger and make this happen.. tbh it would be nice to get this done before the nice weather kicks in also.
IM POOR..
01-24-2020, 10:04 PM | #12 |
IG: @88jae88
1621
Rep 1,734
1. skoold2003 wanting 5/10mm
2. Thevazha 3. Phillyx5m 4. F85MTuned 15/15 & a 20mm 5. BlewX5M 6. 7. 8. 9. 10. I just need to update with the sizes the other guys are looking for, I'm sure they'll pop up and then I'll update.
IM POOR..
01-24-2020, 11:30 PM | #13 |
128
Rep 135
Im seriously in if they can make 10mm...
01-25-2020, 04:23 PM | #14 |
12971
Rep 18,717
FYI, wheel spacer is not any size will fit to any car.
There is a limitation. For this F85/F86 Chassis, the front hub lip height is 14mm. And the stock wheels and most wheel manufacturers have 4-5mm champered back pad to help guiding the wheel into the hub. You will need at least a few mm of the wheel to sit on the hub, instead of just hanging by the lug bolts. So, based on my calculation and what I have been selling, 5mm is the maximum you can go before it will need to go hubcentric. While to go with hubcentric, on the front hub, a minimum thickness would be 15mm. While the rear is 12mm. Hope this information help. I have sold hundreds set of H&R wheel spacers for F15/F16/F85/F86 chassis.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
F85MTuNED1620.50 |
01-25-2020, 04:33 PM | #15 |
IG: @88jae88
1621
Rep 1,734
For myself I wanted to run 15mm on all 4 corners for my stock 21's and if I get rims I'll order a custom offset then I won't have to run one at all. But in the meanwhile my fall / winter setup will sit very nice.
IM POOR..
r33_RGSport12971.00 |
01-25-2020, 10:30 PM | #16 | |
128
Rep 135
01-25-2020, 10:37 PM | #17 | |
12971
Rep 18,717
Been selling that setup for years.
01-25-2020, 10:38 PM | #18 | ||
12971
Rep 18,717
You can't even do hubcentric below 15mm.
01-26-2020, 02:34 AM | #19 | ||
IG: @88jae88
1621
Rep 1,734
Besides all of that I just like to be different so even if this little venture doesn't work out I'll probably see what spacers guys are running in Europe and go with that.
IM POOR..
01-26-2020, 07:42 AM | #20 | |||
12971
Rep 18,717
H&R been doing it for more than 30 years and it is made in Germany. While FC is brand new company. Making wheel spacer is not space engineering. All it comes down to is the material and tooling quality. As I mentioned to my customes and others, even I can and was offered to have my own brand. But I don't want to, because I don't want to fail you guys. H&R is German company, TUV approved quality and manufacturing process. Been used around the world for street and track purposes. I have a few customers that switched from other brand to H&R because some issues with the cheaper popular brands that they were opted too. But, so far I have heard good things about FC. Its main sales pitch is weight saving. A few grams weight saving compared to H&R.
01-28-2020, 03:40 PM | #22 |
IG: @88jae88
1621
Rep 1,734
1. skoold2003 wanting 5mm / 10mm
2. Thevazha 3. Phillyx5m 15mm / 15mm 4. F85MTuned 15mm / 15mm 5. BlewX5M 6. 7. 8. 9. 10.
IM POOR..
