      01-21-2020, 12:33 AM   #1
n55blain
Drives: 2011 e82
Will this setup work? 235/40 and 265/35 on 18" VMR v703
Am looking to purchase a used set of VMRs.
front: 18x8.5 et40 235/40/18
rear: 18x9.5 et45 265/35/18
Will the above setup work without rolling fenders? Stock suspension, tires are MPSS.
I've searched and think this has been done before, but with different sized tires.
Thanks in advance.
      01-21-2020, 11:59 PM   #2
TM9030
Drives: N/A
The rears will rub, you'll have to roll the fenders.
I'm not too sure about the fronts but you might need a spacer and/or some negative camber. We have little room to play with up front.
      01-22-2020, 12:35 AM   #3
TboneS54
YNWA
TboneS54's Avatar
Drives: 2004 M3 6spd & 2011 M3 DCT
Esp since mpss have beefy sidewall.
/// 2004 Silvergrey M3 · Coupe · 6MT · Slicktop · zero options
/// 2011 Jerez/Bamboo E90 M3 · DCT · Slicktop · IG: @na.s54
      01-22-2020, 09:58 AM   #4
Eyeman
Eyeman's Avatar
121
Drives: 2008 135 blk, blk, step
Yep, I run a similar setup (but on 19's which really should not matter). On the front you might rub on the strut or the fender or might be OK, it will be very close. On the rear, I doubt you'll be able to drive it home even if you have the shop set you to maximum camber.
I did the rear brake hub mod just so I could run 255 MPSSs. I might could run a 265 now but I don't plan to risk it.
Injen, RR OCC, MadDad Whisper, donut spare, 19x8.5et43fr 19x9.5et45r Volk LE37's, rear fenders rolled/pulled, PSS4S 225/35fr 255/30r, KW V1's, AR coated catless dps, Cross strutbar, CF grills and license plate holder, iCarbon diffuser, ETS black anodized FMIC, M3 control arms, Quaife, ER chargepipe, ForgeDV's, Topspeed Custom Tune, V3sims, Braille, Andrey_GTA rear hub mod, Ebay Mstyle front bumper and performance style side skirts.
      01-24-2020, 11:05 AM   #5
n55blain
Drives: 2011 e82
Thanks, very helpful
      01-25-2020, 06:59 AM   #6
monstruo
27
Drives: M2C
Running 19 x 8.5/ ET35 225 & 19 x 9.5/ ET46 255 MPS4s.
Zero Rub for the front (-2.3camber) with plenty of clearance.
Minor Rubbing on the left rear as the ride height is 0.25" lower than right rear (1inch gap between fender & tire). Need to get it adjusted. Rubbing for both will occur for big dips. (-2.0 camber).
Planning to go 18". Thinking of keep to the same front setup but with 235. Not sure if i wanna stick with ET45 for the rear as i'm planning to run 265 and would rather zero rub. Maybe ET58. Argh, gonna miss the concavity.
      02-07-2020, 10:32 PM   #7
Tallicia
Tallicia's Avatar
Drives: X6 and 1 series
2013 X6  [0.00]
2011 BMW 135i M Spo ...  [0.00]
245/35-18 on 8.5e35
265/35-18 on 9.5e45
does require some fender massaging
      06-02-2020, 12:45 PM   #8
wantmymoneyincash
Drives: 2013 135is
Thanks in advance.
Looking to do the same thing here, did this work for you? My f/r are rolled and I am on stock suspension which will probably be changing soon. Also, I cant find vb3's anywhere lol
      06-02-2020, 01:04 PM   #9
Petro135
Drives: 2008 135i E88
2008 BMW 135i  [0.00]
I'm on 18's @ 8.5" 35 offset and 9.5" 45 offset with stock suspension and rub on highway dips and smaller jolting bumps in the right rear(I'm guessing its hitting the tank fill tube). I run 225/255. I was told not to go 235/265 without fender work. Glad I listened
      06-03-2020, 08:52 AM   #10
wantmymoneyincash
Drives: 2013 135is
Think I might go with et45 and et50 to run a 235 or more later with some camber and a 265 or more later
      08-07-2020, 06:49 PM   #11
shmain
Drives: 135i
Yo Petro, do you think that if you ran a 225/245 on your same specs, you would be rub free? I'm considering getting some wheels with the same specs. 18x8.5 +35 and 18x9.5 +45 and I'm also on stock suspension. The only thing is that I canyon the car from time to time too, so i may reconsider if the rub is more than I'm willing to deal with. That's what my other project car is for
      08-09-2020, 01:32 PM   #12
Petro135
I had 225/245 when I bought my car and I never bottomed out unless it was a big dip. I run the 225/255 on summer tires and I have 225/255 A/S ready to go for cold weather. They are conti dws and seem a little thinner than the falkens Im presently running. We will see if they are the same. But I don't rub very often. Its really not a problem with 225/255
