ARMA SPEED
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > DIY and Coding Discussions
      01-18-2020, 01:25 PM   #1
KeyBoy
34
Drives: F80 M3
EDC ZCP vs CS (base F80)
Looking to get coding for EDC on my F80 (non comp) with stock suspension. Has anyone done the coding for either ZCP and/or CS EDC with stock suspension (non comp)?
Not sure which to go with or if any at all. But based on reviews it looks like either would be an improvement. Sound like sport/sport+ rides firmer but not sure about comfort.
If anyone can share their experience would be greatly appreciated. Thanks
      01-18-2020, 07:44 PM   #2
MNR
268
Drives: 2018 F80 ZCP
Sub’d for the answer. I’ve been wondering this myself...dropping on Swifts.
OP are you stock height or lowered?
EDIT: Just noticed you were on stock suspension.
      01-18-2020, 10:05 PM   #3
CanAutM3
CanAutM3's Avatar
21117
Drives: 2021 911 turbo
The problem is that the base suspension does not have the same dampers as the CP or the CS, so the EDC coding will behave differently than intended.
The M3cs suspension uses the same springs as the base suspension as well as the front swaybar, so you're good there. Ideally, you would want to change the dampers at all 4 corners for the CP/CS ones as well as the rear swaybar. You'll then be able to fully leverage the CS EDC coding.
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black
      01-19-2020, 04:03 PM   #4
KeyBoy
34
Drives: F80 M3
Thanks. If I just left the suspension stock do you think it's still worthwhile to code the EDC to ZHP or CS? Or better to just keep the base programming?
      01-19-2020, 05:12 PM   #5
CanAutM3
CanAutM3's Avatar
21117
IMO, it's best to keep the coding that is optimized for your suspension hardware.
f80post
