01-14-2020, 06:37 PM | #1 |
13
Rep 89
Are UHP summer tires better in wet conditions than All-Season?
Hey all,
Sorry for the spam recently, but I'm getting conflicting information from my local tire supplier versus online/community knowledge. I was told by the supplier today that ultra high performance summer tires should not be used in wet conditions/rain...? My understanding was that summer tires perform better in wet and dry conditions as compared to all season. Summer tires should just not be use in snow/ice and temps below 40'ish. Here are my references. https://www.lesschwab.com/article/su...t-for-you.html https://tires.tirerack.com/tires/Sum...es%20In%20Rain Notably:
That said, I live in Portland, Oregon where it rains a lot and temps can be on the cool side. I wanted to purchase either some General GMax RS or Indy 500's, to which my local tire supplier said this was a terrible idea due to the wet weather. Are they on crack or am I? Can I get these tires without worrying about driving in the rain and occasional moderately cool temps? Thanks!! |
01-14-2020, 06:56 PM | #2 |
1Addict
3233
Rep 7,894
What are moderately cool temps. Also really matters what your output is. Reason I mention this is at 500tq and 50deg in the wet, you're gonna snap out no matter what tire you have on if you goose it.
70 deg wet and stockish tq? Yeah. Summer tires with adequate ribbing are better. But, time for real talk. If you're concerned about wet performance you shouldn't be looking anywhere but Michelin PS4S or Yokohama AD08R.
chris_flies3027.00 Rmtt8211.00 |
01-14-2020, 07:12 PM | #3 | |
13
Rep 89
PS4S are $860 whereas GMax's are $510 |
01-14-2020, 07:44 PM | #4 |
2412
Rep 3,548
For things like braking distances, I'd check out some Consumer Reports copies. I wouldn't suggest them for everything but if it's something you can run an instrumented test on (i.e. braking distances w/ different tires) then I'd totally say check them out.
What sort of performance do you need? Track days? Spirited driving around on-ramps on the way to work? |
01-14-2020, 07:57 PM | #5 | |
13
Rep 89
01-14-2020, 09:38 PM | #6 | |
1Addict
3233
Rep 7,894
01-14-2020, 10:18 PM | #7 | |
C2H5OH
3915
Rep 2,144
but with portland weather, I wouldn't run them. Or the Indys ... I have both on separate wheels right now. I would go Conti DWS-06. For an all around tire it seems to always be in the conversation, even when neither the indy or rs-rr are mentioned. That tells me it crosses lines that other tires don't. And with the Conti you get a good treadware warranty, tire replacement and I thought I'd seen something about roadside all included in the cost. Last edited by iminhell1; 01-14-2020 at 10:24 PM.. |
01-15-2020, 12:14 AM | #8 | |
13
Rep 89
https://www.tirerack.com/tires/tests...y.jsp?ttid=235 On this test they raved about the performance of the GMax RS in wet conditions and still fantastic in dry. Additionally, this tire won "Best new Tire" at SEMA in 2017, (Not that that necessarily means anything lol, but still). But I guess if nobody else in Portland is running UHP summer tires year round then neither should I.... |
01-15-2020, 12:16 AM | #9 | |
13
Rep 89
01-15-2020, 07:27 AM | #10 | |
1Addict
3233
Rep 7,894
That said, generals look decent. Biggest thing with tires is failure rate which anecdotally is higher outside the top tier makes.
01-15-2020, 11:18 AM | #11 |
Sideways and Smiling
3027
Rep 2,860
Drives: In Exuberance
Indy 500's are merely acceptable in the wet. Good hydroplaning resistance (10+mm of tread depth helps) but they just don't stick on a damp road. You'll be all over the place. When they wear, though, they're horribly sketchy. Fun, but sketchy.
Not sure about the GMax RS, it's a new-ish tire. I had Kumho Ecsta PS-31's for a while and they were really good in the wet even when worn. PS4's are where it's at though. They're worth their weight in gold, just about.
2012 BMW 328i 6-Speed Wagon | Deep Sea Blue with Grey Dakota Leather | Manual Swap, 330i Intake + Tune, 3.15 Helical LSD, Öhlins R&T
(SOLD) 2009 BMW 128i 6-Speed Coupé | Monaco Blue with Black Sensatec | chris_flies' 128i thread |
01-15-2020, 12:23 PM | #12 |
YNWA
1043
Rep 813
If I saw any real amount of rain but still wanted to drive spiritedly or had a RWD car with some serious power, I'd go with PS4S. Ridiculously good in the wet (and dry too). I bet the generals and any other mid tier summer tire will be just fine as long as you're not pushing it past about 7/10s or so (daily driver) and the car isn't really a sports car.
Remember, horses for courses.
/// 2004 Silvergrey M3 · Coupe · 6MT · Slicktop · zero options
/// 2011 Jerez/Bamboo E90 M3 · DCT · Slicktop · IG: @na.s54 |
01-15-2020, 03:15 PM | #13 |
59
Rep 96
Your tire supplier is an idiot. The downfall of UHP summer vs UHP all-season is temperature, not moisture. Since the coldest months also happen to be the wettest months, they still right in their one-size-fits-all recommendation for the unwashed masses...But they're right for the wrong reason.
While UHP are not recommended for use below 40 degrees, their performance does also start falling off above that still. In the PNW the UHP summer will probably perform better more of the time for a bit more than half the year, and the UHP A/S will probably perform better more of the time for a bit less than half the year. However, UHP A/S will also typically do better in the warm than UHP summer will do in the cold. The question you have to answer for yourself is which you are more willing to compromise on, and how often would you rather be better off in the Subaru. By all available accounts it sounds like the G-Max RS should be the better wet tire than the Indy 500, and looking at the tread design would intuitively support this, but there is also a more limited real-world data set for it too. On the other hand, I do tend to prefer non-directional tires, especially on staggered setups, and it looks to be the better dry option. Either should be a perfectly acceptable 3-season tire as long as you have reasonable expectations of them. For something in between the Indy 500 and PS4S, the Conti ECS is another recommended option. Last edited by Driven5; 01-15-2020 at 05:00 PM.. |
02-03-2020, 09:42 PM | #15 |
767
Rep 904
I live in Portland and currently run Michelin Pilot Sport A/S 3+, which is the highest performance all season out there. They have as much grip as most summer tires from a few years back, so you likely won’t need more unless you track. I like to do a lot of mountain runs, and it gets cold up there several months out of the year, even when there isn’t snow.
That being said, I’ll eventually get a second set of wheels for summer and track, but I’d go A/S 3+ if only going one set. |
02-03-2020, 10:27 PM | #16 | |
13
Rep 89
02-04-2020, 05:31 AM | #17 |
1541
Rep 3,071
Currently running the Indy FF500 here in Florida. Its rainy & wet regularly. They do great in wet weather. Cold I have no idea. Ha!
I had the Michelin PS3 before these and they were very similar in ride feel. The Michelin has a bit better comfort but not enough to justify 2x the price.
2011 135i w/ DCT | ZSP Sport Pkg | PPK | Ohlins R
02-07-2020, 10:13 AM | #18 |
Just one more taste...
566
Rep 2,011
02-11-2020, 01:20 PM | #19 |
13
Rep 89
Weather has been pretty chilly so I haven't pushed them too hard yet, but they've been great. Im stage 2+ so plenty of power, occasionally barely able to break lose in 2nd in cold weather, 1st is still just overpowered for the weather and tire setup. I'm not actually sure if there are somewhat affordable commercial tires that can hold a WOT launch from first on stage 2+ though? I dunno, out my knowledge base.
