01-11-2020, 11:58 PM | #1 |
965
Rep 5,032
No success Bimmercode brake force display F82 Pre-LCI
Car is F82 2/2015 build, Pre-LCI
I am using Bimmercode on my iphone. I coded a number of other features, all of which took on the very first try. Looked at a few different threads for reference. I did the following: FEM Brake Force Display 5km/h Weak braking (5 m/s2) 3060 ESS_AKTIVIERBARER_AUSGANG bremslicht_blinkend Brake Force Display flashing frequency I tried with both 3 and 5 times per second, neither worked 3062 MAPPING_BRAKEFORCED_L_OUTPUT bl_l MAPPING_BRAKEFORCED_R_OUTPUT bl_r Took my car for a number of passes with a friend watching as I tested braking at various speeds and pedal pressures, but no blinking at all. Any advice is much appreciated!! |
01-20-2020, 02:36 PM | #4 | |
965
Rep 5,032
Every other feature I tried with BimmerCode worked, so I am a little bummed Brake Force did not take. |
01-20-2020, 04:16 PM | #5 | |
Some random guy
292
Rep 312
I can't exactly recall, but any chance there is another ECU that needs coding in order to activate it?
03-16-2020, 02:49 PM | #6 |
965
Rep 5,032
Finally got it. Strangely it only started towork when I changed the activation speed to 10km/h. I want it set at 5, but at this point I will leave it be. If I feel brave perhaps I will try 5 again.
