01-11-2020, 11:46 PM | #1 |
///M SubDriver
1837
Rep 2,784
Drives: 2017 M3, 2020 X7 40i
DIY: Stealth EZPass Install
This is a small DIY for those of you who use an EZPass, but have OCD like me and don't want it on your windshield. I searched for ways to hide it, or at least hide it from view, but nothing fit the bill for me. I know some just throw it in the door pocket, pulling it out when needed. But I didn't like that either. So then on a hunch, I figured I would take advantage of that beautiful carbon fiber roof so many of us have on our F8X's......
I decided to mount the EZPass between the rear map light fixture and the CF roof, attached to the underside of the CF roof. The premise being that the RF signals from the EZPass can be detected through the CF roof, just like through the windshield. I chose the rear light fixture, vice the front, to have more space and because there is a metal frame support rail in that runs along the front area of the roof that I thought would interfere with the EZPass RF signal. This relatively quick DIY took approx 30 min or so. Now on to the DIY..... First, remove the rear light fixture. I used a trim removal tool. There are two tabs that hold it in place which are located at the front two corners of the fixture. The pic below shows the trim removal tool in the approximate location where one of those tabs is located. Slowly pull down on the light fixture as you work the trim removal tool. Once one corner is pulled down a bit, work on the other corner and the light fixture will come out. When the light fixture is removed, disconnect the harness and set the light fixture aside. What you see in the pic below is the underside of the CF roof. The grey padding is sound insulation that is attached to the CF roof panel. I wanted to use double sided tape to attach the EZPass unit to the roof, but I knew it would not stick well to the sound insulation. So I traced the outline of the EZPass and then trimmed away as much of the insulation as I could. Not as precise as I would have wanted, but it won't be seen once the light fixture is re-installed. It took a little while to remove enough insulation, but here is the finished product attached to the underside of the CF roof using some 3M double sided tape. I orientated the EZPass so that the "EZPass" lettering was towards the rear of the car. This is the same orientation if the EZPass were placed on the windshield. Before I re-installed the light fixture I inserted a few layers of cardboard between the EZPass and the light fixture. The idea is to have the cardboard fill the gap to add some additional support on the EZPass to help keep it in place. So, the million dollar question... did it work? Yes it did! I tested it on an overpass toll detector in the HOV lanes on a small strip of I-395 in Virginia. I waited for the transaction to show up on my EZPass statement for final verification that my EZPass was detected. So will this work on F8X's with sunroofs (or F3X's w/o sunroofs and metal roofs)? I would suspect not, either due to interference of the sunroof cassette and/or the metal roof. But I have not verified this myself. Hope this helps others with EZPass OCD such as mine!
///M3 COMPETITION 6MT - 2017 F80 Smoked Topaz Metallic
BM3 / MP-HAS / GC Camber Plates / Carbonstructure Interior X7 XDrive 40i ///M-SPORT - 2020 G07 Arctic Grey Metallic X3 XDrive 30i - 2019 G01 Mineral White (wife's) / 128i 6MT - 2009 E82 Jet Black (son's) Last edited by jmciver; 01-12-2020 at 11:10 AM.. |
01-12-2020, 12:35 PM | #2 |
1618
Rep 2,161
Cool idea though your OCD is different than mine since I couldn't deal with knowing my sound insulation was all chewed up. 🤣
I have a little suction cup holder for mine and it generally travels in the armrest. This only works because I use toll roads just a couple times a month. |
icegrill2078.00 |
01-12-2020, 01:37 PM | #4 |
4925
Rep 3,806
I like how you made a sharpie outline and the next pic looks like you went at it with a sword But I know how hard it is to cut that stuff and it's a neat idea.
01-12-2020, 02:46 PM | #5 |
121
Rep 373
This is what I use. It blends right in with the dash and virtually unnoticeable. Not as discreet at OP but not bad.
https://rover.ebay.com/rover/0/0/0?m...2F254230477245 |
01-12-2020, 05:52 PM | #7 | |
///M SubDriver
1837
Rep 2,784
Now if it didn't work, I may have needed to buy a whole new CF roof .....
BM3 / MP-HAS / GC Camber Plates / Carbonstructure Interior X7 XDrive 40i ///M-SPORT - 2020 G07 Arctic Grey Metallic X3 XDrive 30i - 2019 G01 Mineral White (wife's) / 128i 6MT - 2009 E82 Jet Black (son's) |
01-12-2020, 05:57 PM | #8 |
///M SubDriver
1837
Rep 2,784
Nope, no stickers for the EZPass system that I know of. When I lived in WA state for a while, they used the sticker passes though...
01-13-2020, 08:49 PM | #10 |
1234
Rep 1,164
01-13-2020, 08:59 PM | #11 |
///M SubDriver
1837
Rep 2,784
Ha ha, yeah right. Actually, I have never been a fan of those plate mount EZ Pass units more for theft reasons.....
01-13-2020, 09:09 PM | #12 |
899
Rep 1,009
Are you sure the Ezpass transponder was detected or did they run your tags and match it your transponder? I installed my transponder really high on my windshield and if I’m driving over 35 thru most gates on the toll roads it doesn’t read. I chalked it up to the CF roof. Each toll booth takes a photo and matches my tags to my transponder so it shows up on my statement.
01-13-2020, 09:55 PM | #13 | |
///M SubDriver
1837
Rep 2,784
01-18-2020, 01:44 PM | #14 |
///Multiple
2992
Rep 4,243
Drives: M4 Coupe | M3 | Z4M Roadster
Garage List 2006 BMW Z4 M Roadster [8.81]
2016 BMW M4 Coupe ( ... [10.00] 2018 BMW M3 (Euro D ... [0.00] 2011 BMW 335is Coup ... [10.00] |
So back when the M Performance Carbon Fiber Diffuser was released, people bought that, installed it, and discovered that the "kick to open" trunk feature didn't work. The common explanation given was that the CF acts as a Faraday cage, effectively blocking the signals necessary for this to work. There are several threads and hundreds of posts on this. I have one installed and my "kick to open" feature no longer works. So how does this work, especially since the CF roof if probably thicker than the CF in the rear diffuser?
Is your EZ-Pass only used on toll roads? Here in San Diego, our FastPass allows us to drive in certain carpool (HOV) lane without passengers (for a fee) and can also be used for the Toll Roads located in Orange and LA counties. If you have passengers in a carpool lane, no FastPass is required. With your relatively permanent installation, you'd get charged a toll in the HOV lane even with passengers. I have a gel mat cut to fit in the flat space on the dash to the left of the Nav screen. When I need to use my FastPass in a carpool lane with no passengers I pull it out of the door bin and put it on the gel mat before I get in the carpool lane and it holds it securely, even on the entry/exit ramps. If I have a passenger, I don't need to use the FastPass. If I'm using one of the Toll Roads, I put the FastPass on the gel mat when I first get on and then take it off because it's not needed to determine the distance you travel as the fee is fixed for the limited access Toll Roads. This is the easiest solution for me given the variable nature of how I have to use my FastPass.
The Coupe: 2016 M4 | Sakhir Orange | Black Full Merino Leather | CF Trim | M-DCT | More | ED 5/13/16
The Sedan: 2018 M3 | San Marino Blue | Black Full Merino Leather | CF Trim | M-DCT | ZCP | ED 7/18/18 The Roadster: 2006 Z4 | Interlagos Blue | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12 |
01-18-2020, 02:15 PM | #15 |
///M SubDriver
1837
Rep 2,784
The carpool EZ Pass transponder used here is different than the standard EZ Pass transponder that I use. I have no need for the carpool variant based on how often I use the HOV lanes so my install supports how I use the EZ Pass.
Regarding the faraday cage comment, I am not a composite materials engineer, but what you said does not make sense to me. CF is a composite material with no metallic ingredients - similar to plastic. Therefore, the CF should not interfere with the RF signal from the transponder. The only reason I figured this might not work would be due to the thickness of the CF roof compared to the signal strength of the RF signal coming from the transponder. But as I mentioned above, the proof that it worked was based off what I saw on my billing statement. As for why the "kick" feature didn't work with the CF diffuser, that puzzled me a bit too since the CF should not interfere with the signal. Unless the signal from the kick sensor is so week, the thicker CF was able to interfere with it. FWIW, I have heard that some people were able to get the kick feature working with the CF diffuser installed - albeit intermittently.
SD ///M42992.00 |
01-19-2020, 03:15 PM | #16 | |
298
Rep 584
01-22-2020, 01:19 PM | #17 | |
///M SubDriver
1837
Rep 2,784
All that to say that CF does attenuate RF signals under certain conditions, but is still significantly less than metal. So in my application, with the EZ Pass mounted just under the CF roof, the signal from the EZ Pass transponder is still strong enough to be detected.
