01-04-2020, 11:04 AM | #1 |
441
Rep 624
Vorsteiner GTS-V Front Lip Flew Off
I was on the fwy last night and I hit a high rate of speed. I hear a loud sound and my brand new Vorsteiner GTS-V front lip ends up flying off my car....1.6k down the drain and I had that shit on 2 days lmao.
I don't think it was an install issue and more of a design flaw. I used double sided tape and used more than 8 screws to secure it. Upon closer inspection the screws are still attached but the front lip is gone. Doesn't that mean the lip broke where it shouldn't have? Need suggestions for front lips that won't fly off going 150+mph. |
01-04-2020, 06:29 PM | #4 |
5462
Rep 5,154
On researching CF attachment it seems that much attention needs to be paid not to crack the fiber at the screw holes. Many brands come dimpled or pre-drilled small. Drilling obviously increases risk of cracking. Any vibration also increases crack risk or progression of cracks. My Vorsteiner Evo (4000BMV) has been up to speed without any issues. I've worked many years at a car shop in the past so I did have a few tricks...
Best practices: -Scotch/masking tape any holes before drilling -Dremel diamond bits are great to start holes and round them to size -If no Dremel available I've had good luck starting with small drill bits at high speed, then progressively larger bits at high speed (use new/sharp bits!) -A tiny swipe of clear nail polish (ask your girlfriend for Top-Coat) on the drilled hole edge will settle or prevent fray -Tape over both sides of the hole as the nail polish dries so it dries perfectly flat -Use 91% ISO alcohol (repeat, use multiple paper towels, especially for ceramic coated areas) to clean all/both surfaces where tape will be applied or attach, and wipe dry with clean paper towel -One wipe of alcohol on ceramic = contaminated towel, fold and continue with a new/fresh wipe surface -Only use real 3M brand double sided tape, 5/8 or wider, and 1in if you can -Cut all tapes 2 inches too long, peel and cut off 2 inches of tape leaving a 2 inch pull-tab that you can easily grab and pull out AFTER you have ALL your screws in three full turns (less fiddling = less cracking) -Double-side tape all contact surfaces, even under screw holes, which reduces vibration further -Use the right size screw for the right hole -As our buddy above mentions, use washers beneath all screw heads, and I even add thin rubber washers under the metal up against the CF, so I can tighten the screws with little risk of cracking CF or tearing out bumper plastic -If you need to remove your spoiler one day, use a dental floss garotte on wood pulls to cut through all tape foam before you remove screws the last couple threads
'18 F80 Base 6MT | '19 F82 Exec DCT | '18 F82 Comp Exec DCT | '23 G80cx
01-04-2020, 11:41 PM | #5 | |
441
Rep 624
01-07-2020, 05:33 PM | #7 |
106
Rep 211
It definitely sounds like an installation error that didn't secure the lip properly. We've seen tons of these lips get pushed past the 150mph mark. It should definitely have withstood the elements. TopJimmy has some great tips above, that if you follow, you should be able to push your car to the absolute limit with no issue. We carry the RSC front lip that is super aggressive and makes for some serious downforce, but even that holds up really well to high speed/ downforce. Best of luck on round 2 with your GTS lip!
01-08-2020, 12:16 AM | #8 |
604
Rep 871
3m tape doesn't do shit at 150mph. It's all about the screws and 8 screws is not enough. That's good to maybe 100mph. If you want to go that fast you need at least 20 screws or nuts and bolts
01-09-2020, 09:53 AM | #10 |
Mr. sat_yas
631
Rep 245
Oh man...that sucks. Sorry to hear that, thanks for the heads up.
01-09-2020, 02:14 PM | #11 |
Bit by Modbug
258
Rep 1,109
As I was installing my lip, I found this thread and it scared me enough to add 7 bolts with huge washers to my lip. Now I have no idea how to re-attach the splash guards.
Current: F86 | F30
Past: Cayenne GTS | Abarth 500 | YMB M4 | X6 M50i | E92 M3 6MT | X3 M40i | E92 335i Stage 3 | G35 Coupe |
02-16-2020, 10:15 PM | #15 | |
965
Rep 5,032
My CS rep lip is held on with 10 bolts with washers on both sides and 3m double sided tape, and has held up to speeds up to 170mph. |
