12-27-2019, 11:17 PM | #1 |
Rep 28
Tune
Hi guys
Im in Melbourne, i had my car tuned but the dino result was not good, i was recommended to have it on dino again in other place.Would you guys recommence any places to run the dino and also experience in M3 modifications ? Thank you.
12-28-2019, 07:25 AM | #3 |
10
Rep 104
What is not good and what where you expecting. Are you just looking at peak number or area under the curve.
12-28-2019, 06:36 PM | #4 | |
Rep 28
Thank you for your replies. I was give a dino chart and was not explained what was was about so i could no understand what i presented. There one number said max 230kw, which i believe wss the peak and it was much lower than stock m3 309kw. Are there any other m3 specilists around in Melbourne u guys kniw of, just want a couple to compare. Cheers Merry Christmas, Happy new year !!! |
12-28-2019, 11:35 PM | #6 | |
10
Rep 104
12-29-2019, 09:20 PM | #7 |
185
Rep 780
You gotta understand that dyno's are meaningless unless you get a baseline and then re dyno with any mods on the car. Let me put this into perspective, a car with a tune and another car with the same exact tune can dyno at 2 entirely different places and make 2 entirely different numbers. Does that mean the one that made more is faster? No. It's because there's so much variation between dyno's. The only reason you should use dyno's is to see baseline stock numbers and re dyno with any modifications to see how much power you make with those mods.
12-29-2019, 11:34 PM | #8 | |
Rep 28
i did not know that, that was what i meant i was not explained when i received the chart.
12-29-2019, 11:52 PM | #9 | |
Rep 28
i did not know 309kw was the crank horse power, so i expected a bit better than that. i had the Performance M3 exhaust and Eventuri air filter on. I am very happy driving my car.
12-29-2019, 11:55 PM | #10 | |
Rep 28
any other garage you guys can recommence in Melbourne ? cheers
12-30-2019, 02:56 AM | #11 |
10
Rep 104
As noted a dyno somewhere else is a waste of money in my opinion. What are you going to do if the number is south of the one you have. If you can notice an improvement behind the wheel isn't that the main thing given you don't have a baseline.. If you are that upset, and want to get a number, surely you would go back to them and say can you flash it back to stock tune , Do a dyno reading then flash back their file and do another and that should be close to the one you got. Negotiate the dyno price based on say three runs and labour only to flash the tunes. If they don't come to the party call them out on this forum. I would not touch the airbox. It will cost you nearly as much to remove it and reinstall it than what the setup is worth and in my opinion, good for a bit more engine noise and a tiny bit of extra hp that's not worth getting upset about. Just out of interest why didn't you post on here before getting the tune for some advice / opinions.
12-30-2019, 03:55 AM | #12 | |
Rep 28
I did not put a post up here to get some advices because i kind of trusted those guys and believed they knew what they were doing, would do it right to me. Sadly it was not... Cheers |
12-30-2019, 06:05 PM | #13 |
3907
Rep 4,172
Do you know what brand of tune they did for you? If it's an off the shelf tune from some tuner like Evolve, BPM, etc, they should have given you a cable for you to re-flash your car back to stock.
If it's a custom dyno tune, then the tuner would have done many dyno runs from start to finish and would have the stock dyno numbers saved on the dyno computer. |
12-30-2019, 10:18 PM | #14 | |
10
Rep 104
Did the OP even ask if they have a dyno sheet pre tune. I got the impression they were only given a dyno sheet from one run post tune. Does not mean a pre tune dyno sheet doesnt exist. |
12-30-2019, 10:52 PM | #15 | |
Rep 28
Mine should have been a shelf tune. But i was not given any cable. |
12-30-2019, 11:51 PM | #16 | ||
185
Rep 780
12-31-2019, 01:30 AM | #17 | |
3907
Rep 4,172
Custom dyno tune = The tuner will put your car on a dyno and tune it specifically for your engine and mods. This is more optimized and usually extracts every last HP from the engine/mods. It involves putting the car on a dyno and making tweaks and dyno-ing to see the results, repeatedly, until the tuner is satisfied that no more power can be obtained. As such, it's much more expensive, more time consuming, and the car needs to be with the tuner for them to tune it. If you have a custom dyno tune, the tuner will have multiple dyno runs from start to finish. If you have a canned tune, ask the tuner what tune did they use. |
12-31-2019, 03:53 PM | #19 |
3955
Rep 3,993
Peak numbers are meaningless
01-01-2020, 08:24 AM | #22 | |
Rep 28
This is all new to me. I think I may have to start from learning to read the chart. Any recomendation where i can find a good guide to underatand the chart. Cheers |
