BMW M5 F90 (2018+) General Forums Cosmetic Modifications    HOW TO: Carbon Fibre Gear Shifter Install
      12-27-2019, 10:58 AM   #1
ste0803
ste0803's Avatar
United Kingdom
342
Drives: Purple F90 M5 - Stage 1
Lightbulb HOW TO: Carbon Fibre Gear Shifter Install
Hi guys,
I did search and couldn't find any how to on the install of the carbon fibre gear shifter so thought id take some pics along the way and give a brief explanation to make it easier for anyone trying this in the future.
Tools Needed:
Plastic Trim Tools
T7 Torx
First take a thin trim tool and pry out the Gear Intensity switch from the top of the lever.
Then remove the large plastic cover from the top of the lever, I found this was best done starting at the top. working the way down the edge and then pull upwards.
Remove the 4 torx t7 screws.
Starting at the top pry each silver side piece off working downwards, at the bottom you need to pull out and up.
Remove the lower plastic trim with the plastic lighting prisms. Start near the leather and pry towards the rear of the car.
Swap the switch rubbers & gasket from the old piece to the new piece, here you can see 1 switch rubber removed and one still in place at the top of the piece.
Follow the previous steps in reverse for installation. Please make sure you have transferred the switch rubbers and gasket prior to installation as once you've clicked the top cover on and rocker switch its too late to fix as you'll more than likely damage some clips removing the items again.
Hope this helps someone and makes the job a little easier.
Finished Article:
Thanks
Steven.
Appreciate 7
limeypride4425.00
Jocko78103.50
NoMods1108.00
TFERG30.50
afo818254.50
Egrunt553.00
      12-27-2019, 11:29 AM   #2
euro*
euro*'s Avatar
1658
Drives: F90 M5
Thank you for the write-up
ste0803342.00
      12-30-2019, 11:34 PM   #3
salraf
59
Drives: F90 M5, prior F80 M3, E60 M5
New shifter looks awesome..
      01-10-2020, 07:02 AM   #4
Nomana
Nomana's Avatar
1466
Drives: BMW
Thank you for diy
      01-11-2020, 07:26 AM   #5
MCOMP
MCOMP's Avatar
199
Drives: 19' M5 Comp.
That looks great, I love how the leather part stays and just the aluminum is replaced.Are you planning to carbon Fiberize the rest of the tacky aluminum trim seen all over the interior especially on the steering wheel? The plain aluminum cheapens an otherwise beautiful interior.
Btw, what part number is that shifter piece? Thanks
2019 MBB/Aragon M5C
M Performance: Exhaust Tips/Pro Spoiler/Rear Diffuser. H&R 11/11 Spacers ACG Carbon Kevlar Pads XPEL Front PPF Ceramic Pro Silver 20% Tints Instagram #m5comp
      01-12-2020, 03:33 PM   #6
ste0803
ste0803's Avatar
United Kingdom
342
PN: 61312455281
I don't like the Performance steering wheel so probably won't change that, if I were to do anything id probably get the current trim skinned to keep the gap in the middle.
I've already changed the paddle shifters to Paddleshifterz, see this thread:
https://f90.bimmerpost.com/forums/sh....php?t=1682919
      01-13-2020, 12:41 PM   #7
IND-Distribution
BMW obsessed
IND-Distribution's Avatar
9587
Drives: G82 M4 / G87 M2
Thank you for sharing and it looks great installed.
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMYOUTUBEFACEBOOKFLICKR
      04-22-2020, 11:33 AM   #8
MXNSITH
199
Drives: 2020 M5C, 2019 i3 REX, 2010 Z4
Thanks
Steven.
How do you feel the CF compares to the interior trim CF in your build? Is it so different that it sticks out, blends in better?
2020 M5 Comp
2019 i3 Rex
2010 Z4 35i
      04-24-2020, 11:43 AM   #9
ste0803
ste0803's Avatar
United Kingdom
342
Hi there.
I have numerous carbon pieces within the interior now, shifter, paddle shifters and the steering trim.
I prefer the darker look and I think the aluminium carbon look trim is very classy and suits this car well and adding some extra ‘real’ carbon looks great to me.
See this image.
Appreciate 2
MXNSITH198.50
r33_RGSport12967.50
      04-24-2020, 12:08 PM   #10
MXNSITH
199
Hi there.
See this image.
I have the same interior so this helps. Thanks!
2020 M5 Comp
2019 i3 Rex
2010 Z4 35i
      04-25-2020, 04:46 AM   #11
ste0803
ste0803's Avatar
United Kingdom
342
Great, here is another.
Appreciate 2
r33_RGSport12967.50
MXNSITH198.50
      04-25-2020, 08:35 AM   #12
MXNSITH
199
I like the carbon trim you added to the steering wheel
2020 M5 Comp
2019 i3 Rex
2010 Z4 35i
      04-28-2020, 11:16 PM   #13
r33_RGSport
r33_RGSport's Avatar
Drives: G09 XM, G05 X5 40, 991.2 T
[img]https://live.staticflickr.com/65535/...da5e1e1e_b.jpg[/img]
I believe that is AutoTecknic's.
Same as what I have on my X3MC and a few if my customers.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com
PM for Everyday DEALS!!
MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri
Active Autowerke • KW • H&R • Ohlins • Remus • and more...
      05-02-2020, 02:25 PM   #14
ste0803
ste0803's Avatar
United Kingdom
342
Sure is, autotecknic part.
r33_RGSport12967.50
      05-10-2020, 09:38 AM   #15
MXNSITH
199
Thank you for the writeup, knocked this out yesterday and your step by step helped a ton!
For those with a 2020, the screws are a T6 Torx. It's also important when putting in the new large cover, to put it in straight down, don't rock it in by installing the bottom first then the top (which would have been the opposite of removing it).
2020 M5 Comp
2019 i3 Rex
2010 Z4 35i
      02-05-2023, 02:06 PM   #16
NoMods
NoMods's Avatar
1108
Drives: 2022 M5
2022 M5  [10.00]
ETA: just did mine and it was easy overall, removing the gear intensity switch took me about 15 mins and i was careful in not to snap anything off and never had to do anything with the rubber gaskets. it was a T6 used also.
      02-13-2023, 09:28 PM   #17
Maverik259
Maverik259's Avatar
Drives: F90 M5 / F15 50i
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Damn you bmw for not coming out with a CF interior for the 5. You suck!
'07 Yamaha R1 (sold)
'06 C55 AMG (sold)
‘?20 M5, MP Carbon Pro Spoiler, MP Carbon Diffuser, MP Black grille and gills, MP Carbon Mirrors, CF side sills, 789M w/ Ti studs, eventuri, Dinan X pipe
'14 X5 50i (wife’s now)
      02-14-2023, 10:42 AM   #18
NoMods
NoMods's Avatar
1108
Drives: 2022 M5
2022 M5  [10.00]
left hand drive version
      03-09-2023, 11:40 AM   #19
CrashCade
112
Drives: '19 M5 Comp,
I just purchased this trim used. Is it only the trim that is swapped out or are there other parts that are included and MUST be swapped?
