01-03-2020, 12:00 PM | #1 |
339
Rep 152
HOW TO: Carbon Fibre Paddle Shifters (Paddleshifterz)
Hi All,
Following on from my previous gear shifter install I thought I would do the same for the paddle shifters from @Paddleshifterz https://paddleshifterz.com Firstly you'll need to open the boot (trunk), make sure your wheel is centred and your seat is in a position where you can access the bottom of the wheel. Tools Needed: Plastic Trim Tool 10mm Spanner or Socket Towel / Cloth T15 Torx Flat head screwdriver Small pointy device ( I used an Allen key) First of all you need to go to the boot and take the trim tool too prise the boot floor up and lift it all the way, I used a drying towel to wedge the boot floor open. Next take the 10mm socket and disconnect the negative terminal on the battery. Next take a towel to keep the terminal from reconnecting. Now you need to remove the airbag from the wheel, insert a flat head screwdriver into the slot on the base of the wheel and push upwards, the aim here is to push this spring tab holding in the airbag, see both below pictures. Now take the tortx and remove the screw holding on the paddle shifter, you may need to move the blue connector out the way to reach this. Now once the paddle shifter is loose you need to push the retaining pin out, one side is thicker than the other so it will only push out one way. Once this has been disconnected you can then disconnect the paddle from the switch assembly, you can see from the below photo there is a spring in the centre and 2 clips either side, you slide the paddle backwards and it comes loose. Be sure not to lose the spring (its easily done) The installation of the new paddles is the above in reverse, slide the new paddle over the switch assembly making sure the spring remains in place. Push the new paddle onto the assembly and push the retaining pin back through both parts. Re-sit the completed assembly back onto the wheel and re-tighten the torx screw. Ensure that the blue clips are pushed back to either side and re-attach the airbag. Once this is done you can reconnect the battery and enjoy the new shifters. Thanks all for reading. Last edited by ste0803; 01-03-2020 at 12:10 PM.. |
01-03-2020, 12:09 PM | #2 |
339
Rep 152
Review:
After ordering these only a few days ago (over the holidays) they arrived quickly. The packaging is great to ensure that the items arrive without damage. Included was a free bag of Haribo! Opening the box it's filled with dense foam. In the box, Quality carbon fibre shifters Overall I'm really happy with the product and as the standard f90 paddle are so small I can confirm that you can get the car to shift by pressing on the far bottom or far top of these shifters (unlike the stock shifters in the F80/F82 which just flexed and didn't shift) |
cruzzinlow97.00 |
01-13-2020, 04:24 AM | #4 |
339
Rep 152
Some more pictures of the paddles fitted.
Jocko78103.50 cruzzinlow97.00 |
02-22-2020, 02:59 PM | #5 |
254
Rep 494
These look great and a reasonable price too. Are they cold metallic feeling vs the oem plastic? Such a miss by BMW with the paddles on the m5.
cruzzinlow97.00 limeypride4418.50 |
03-07-2020, 03:19 PM | #6 |
97
Rep 213
agreed, the paddles on the F8X were much better, the F90 paddles are too far in also. these look like great option
2019 M5 Competition
2018 X5 50i M-sport |
03-10-2020, 05:55 PM | #7 | |
254
Rep 494
They feel great does not add more "engagement" of the paddles but the feel and look are far superior to stock. Great add for the f90 or g platform 5 series! |
05-13-2020, 06:22 AM | #8 |
47
Rep 62
OP - thank you for the install write up. Near the spring, there is a black plastic piece you don’t want to lose. I just installed these shifters. They look nice, but I don’t like how they angle away from the wheel. I would prefer if they were parallel to the wheel.
05-15-2020, 07:38 PM | #9 |
82
Rep 142
I heard a few reviewers on YouTube lament the plastic, one said cheap plastic feel of the rear of the oem paddles. While the cf are very nice, I do not find the oem plastic cheap feeling at all. Maybe my fingers aren’t that sensitive. Lol.
10-28-2020, 05:34 AM | #10 |
Rep 6
Hi,
i would like to buy them but i'm afraid of the angle of them. Is this a pb in term of esthetic and everyday use? I ordered first the autotecknic ones but there's a 3 weeks wait thanks for the advices |
r33_RGSport12805.00 |
10-28-2020, 12:14 PM | #11 |
377
Rep 541
I have the autotecknic carbon ones installed, they do not get in the way of anything. I don't think these will interfere with anything either, not sure what you mean by everyday use.
10-29-2020, 09:03 AM | #12 | |
12805
Rep 18,628
There is good and bad about it. Good for guys with long fingers. Bad because it closes the gap between the paddle and the stalk. You might accidentally move the blinker stalk or wiper stalk. Also, the backing doesn't cover the steering wheel contour. It still uses BMW's previous paddle shifter backing design. While the AutoTecknic, it is parallel to the steering wheel and the backing follows the steering wheel contouring.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com March SALES!! Evolution Racewerks - Until 04/01 | PM for DEALS MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
10-31-2020, 02:51 AM | #13 |
339
Rep 152
Paddleshifterz are releasing a new G series paddle to match in with the new G series of cars (the f90) included.
You may want to wait for these, I love the angle of the paddles I have now but as mentioned the gap between the paddle and the stalks is quite narrow. I've never knocked the stalks by accident and I like that they're angled away when not used and come in-line when pulled. |
11-03-2020, 06:35 AM | #14 | |
392
Rep 279
07-20-2021, 07:17 PM | #16 |
4133
Rep 7,154
Drives: F90 M5 / F15 50i
try a larger flat head screwdriver. It takes some practice to find the sweet spot. Took me awhile on my X but now its a sinch.
'07 Yamaha R1 (sold)
07-20-2021, 07:51 PM | #17 | |
4133
Rep 7,154
