11-15-2019, 05:43 PM | #1 |
103
Rep 125
Alcantara Steering Wheel Central Bolt Reuse
Hi,
Planning on installing a new alcantara wheel to my F80 this weekend. Read through the DIY thread and the install seems straightforward enough. What I didn't see was anyone replacing the central bolt to the steering column. Is it safe to reuse and torque this bolt down or is it advised to change this bolt each time? Tia |
11-15-2019, 08:05 PM | #2 |
4924
Rep 3,806
It's one of those things...yes the instructions say to replace the bolt, but 99% reuse the bolt without issue. I would bet even most dealerships. It's one part german engineering, one part liability protection.
11-16-2019, 04:24 AM | #4 |
103
Rep 125
I couldn't actually find anywhere in the instructions where it says to replace the bolt. If it's not a designated one time use only bolt then no point in replacing I guess?
11-20-2019, 07:14 AM | #5 | |
141
Rep 258
I reused the bolt on mine, 9000km and it hasn't fallen off yet *knocks on wood*
2019 M4 ZCP / Yas Marina Blue
M-Performance Front Splitters / M-Performance Rear Spoiler / Rieger Tuning Side-skirt Extensions / Carbonwurks Rear Diffuser / Alcantara M-Performance Interior Accessories |
11-21-2019, 06:54 AM | #6 |
103
Rep 125
Thanks guys. I wimped out in the end. For the sake of a couple bucks I went ahead and changed with a new bolt. Surprisingly the bolt torque is quite high 48 ft lbs
