10-14-2019, 10:19 AM | #1 |
///M SubDriver
1837
Rep 2,783
Drives: 2017 M3, 2020 X7 40i
Using BimmerLink or BimmerCode w/ENET Cable & Ethernet to Lightning Adapter
I recently received updates for both BimmerLink and BimmerCode for iOS which added the functionality to use an ENET cable as the interface to the car. In order to use the ENET cable with an iPhone, you would need a lightning to ethernet adapter for the iPhone. I don't use either app on a regular basis, but when I do, I would prefer to use a wired connection for better stability and data transfer rates. I have an ENET cable but only use it with my laptop, with either E-Sys (for coding) or ISTA (for diagnostics).
However, I am curious if anyone has used this hardware combo with an iPhone and which hardware works well - specifically the lightning to ethernet adapter (since not all adapters are created equal when it comes to working properly and consistently with iPhones). Thanks!
///M3 COMPETITION 6MT - 2017 F80 Smoked Topaz Metallic
BM3 / MP-HAS / GC Camber Plates / Carbonstructure Interior X7 XDrive 40i ///M-SPORT - 2020 G07 Arctic Grey Metallic X3 XDrive 30i - 2019 G01 Mineral White (wife's) / 128i 6MT - 2009 E82 Jet Black (son's) |
10-15-2019, 03:37 AM | #3 |
///M SubDriver
1837
Rep 2,783
Depends on what your definition of the "best" adapter is - if it is other than price. Two very capable and reliable (albeit expensive) wireless adapters (Kiwi and OBDLink) are $100 and $80 respectively. While lightning to Ethernet adapters can be had for as cheap as $20. My question is not about cost of the hardware, but about if anyone has used the Ethernet hardware and which hardware works (or not). Even the best wireless adapters can still have issues just due to the inherent weaknesses of any type of wireless technology.
10-21-2019, 06:34 PM | #4 |
61
Rep 590
Drives: MG F80 ZCP
I just finished coding using BimmerCode with an ENET cable and Lightning to Ethernet adaptor.
It didn't work with my iPhone X, but I plugged it into an old iPhone 7 and it worked perfectly. Not sure what went wrong there. |
10-21-2019, 08:26 PM | #5 |
///M SubDriver
1837
Rep 2,783
Which lightning to ethernet adapter did you use? The only thing I can think of is that the chip set in the adapter is not compatible with the newer iPhones ??? Either that or the iOS version on your X is too new for the adapter....
10-22-2019, 09:12 PM | #6 |
61
Rep 590
Drives: MG F80 ZCP
Brandless - one just got off eBay for like $10.
05-10-2020, 12:04 AM | #7 |
367
Rep 257
Device: iPhone 11 Pro Max
Can confirm this cable works: used both BimmerCode and BimmerLink https://amzn.com/B07XHQCQSN It is fast! Not a fan of the wireless adapter. Hardwired is extremely quick. Out of abundance of caution I still hook up my car to a 70A flash mode charger. Hope this helps someone. |
sappersix28.50 AndrewC198910931.00 |
05-10-2020, 08:00 PM | #8 |
252
Rep 631
Drives: 2014 M6 Grand Coupe CP
i have tried it with my 6s. It gets the ip address but then says "device not compatible with this phone" when I try to use bimmer code.
F06 M6 Grand Coupe CP
Sapphire Black Metallic The drive is the destination |
05-25-2020, 09:18 PM | #9 |
Rep 19
I use BimmerCode on my F80 and G20 with iPhone X + ENET Cable/Lightning Adapter.
No connection issues, high-speed, inexpensive... I use the following: ENET Cable https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Lightning Adapter https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
flexspec367.00 |
05-27-2020, 08:29 PM | #10 |
252
Rep 631
that is the exact same combination I use. I have the iphone 6s+. Could that be the problem?
08-03-2020, 03:48 AM | #11 |
553
Rep 646
Wow - is this really a true alternative? As a Mac guy privately and with a PC from work that's totally locked down, I have no real coding options at the moment.
This would be amazing for small codes. I have installed a 6WB in my F36 and miss small features I need to enable - it looks to be a true full coding option this.
| 2021 Tesla Model 3 |
08-17-2020, 03:57 AM | #12 |
553
Rep 646
Just for good measure, I can confirm that this adapter works with my iPhone 11 Pro
https://www.amazon.co.uk/gp/product/...?ie=UTF8&psc=1 Pretty damn cool app
10-22-2020, 11:37 PM | #13 |
29
Rep 110
Thank you! Just ordered. I'm with you on preferring a stable wired connection.
'16 M4 ZCP | 6MT | YMB | CSAT
'16 Aprilia Tuono V4 1100 RR, '08 FJ Cruiser |
r0wr589.00 |
02-04-2021, 06:04 PM | #14 |
rwd = fun
19
Rep 50
Drives: M4CP
Apologies for the thread revival but after using a Veepeak OBDCheck BLE+ adapter, I just couldn't stand how slow it was anymore so decided to get an ENET cable and the following Ethernet to Lightning adapter: https://www.amazon.co.uk/gp/product/B086MQGW2X
Unfortunately it does not appear to work on my iPhone 11 Pro though. I put the phone in airplane mode, turned off BT, WiFi and had the car on ignition with nothing else running (Heater, seats etc all off). And it just simply wouldn't connect, over and over again. Bimmercode have a page where it says if it keeps failing, just get out the car, lock it and leave it a while, then try again. Did this, but still nothing. Help ? Edit: Forgot to add that the phone clearly recognises the adapter as it assigns and IP address just fine and I have previously used the ENET cable to flash CarPlay Fullscreen so both cables work as they should, it must be the app or just my phone? I ll try with the iPad tomorrow.
2016 F82 ///M4 Competition | Individual Mexico Blue - Fully loaded, CCBs, MPE ect.
Gone: '18 M2 LCI Manual, '02 E46 M3 SMG, '05 E46 M3 Manual |
02-05-2021, 06:03 AM | #15 |
///M SubDriver
1837
Rep 2,783
It is the app, unfortunately. I have had periods of time when it would not connect with BimmerCode, but would connect with BimmerLink and a few other apps I have to interface with my car. I have no idea why BimmerCode does this from time to time, especially when BimmerLink (made by the same developer) connects every time. I just ended up being patient and it eventually did connect.
02-07-2021, 03:26 PM | #16 | ||
33
Rep 92
I have the opposite situation. My ENET will connect to Bimmercode but not to Bimmerlink. Tried everything. I'm in android BTW. It must be an app issue. |
03-12-2021, 01:45 PM | #17 |
Rep 2
Hello Everyone, [first ever bimmer forum post]
I have just got this setup to work on my iPhone 12 Pro. Hope this helps. I received my no name amazon lightning port to RJ45 adapter and ENET cable. Excited to start coding I was quickly unexcited to see I could not get the app to read my new adapter. I read this thread looking for answers and since I saw comments were surprisingly recent and no solution found I decided to register an account and detail my steps for everyone here. March 12th, 2021 iPhone 12 Pro (up to date iOS) BimmerCode app (updated today actually) RJ45 adapter (ethernet adapter) ENET Cable Step 1) Plug in Enet to OBD2 Step 2) Plug in rj45 adapter to Enet cable (do not plug into phone yet) Step 3) Put the car in auxiliary mode let everything turn on and chime Now go to your iPhone DO NOT PUT YOUR PHONE IN AIRPLANE MODE Disable the following: 1.Cellular 2.wifi 3.Bluetooth (3 bubbles in the upper left of the shortcuts screen) Step 4) Plug your already connected adapter into your iPhone's lightning port. **IMPORTANT** When you disable cellular and wifi and bluetooth on iPhone those services do not instantly disconnect (they actually never truly disconnect but thats for a different forum group) give it a solid 30 seconds for the phone to run its scheduled 'shut downs' once data is disabled. Step 5) Confirm the "Ethernet" Line has appeared in your iPhone's settings below your Apple ID, between "Bluetooth" and "Wi-Fi" (you may/probably will have to disconnect and reconnect the lightning adapter to get the "ethernet" line to appear Step 6) Click on "Ethernet" -> Click the "USB 10/100 LAN" Step 7) Click on "Renew Lease" and confirm you want to renew the lease on the pop-up Open Bimmercode App RESIST THE URGE TO CLICK ON CONNECT AS SOON AS THE APP OPENS Step 8) click the settings gear wheel in bimmer code app (bottom right) step 9) change your adapter in the settings to literally any adapter YOU DO NOT HAVE Step 10) on Bimmercodes main screen click "Connect" It should very quickly return an error Step 11) go back into bimmer code settings Step 12) Select "ENET Cable" as your adapter type Step 13) go back to the main bimmercode screen and click "connect" You should now see the prompt of selecting your vehicle model and type appear and it *Should* connect successfully! Hope this helps! |
03-23-2021, 10:56 PM | #19 |
10931
Rep 4,551
Drives: 2015 328d xDrive
Tried this step by step with an iPhone 12mini on latest OS and latest bimmercode update as of today's date and it didn't work. Enet shows IP address in settings so it doesn't appear to be faulty hardware.
Edit: After emailing Stephan and sending my logs he had me disconnect my battery tender and try again using the 8 steps in the manual (under app settings) and it worked first try. Figures.
07-27-2021, 09:57 PM | #20 | |
281
Rep 387
The below was spot on! Thought my cables had gone bad. A big mahalo for posting this and saving me from thinking I had to buy the CX bluetooth.
2020 540i MSport | Alpine White | Mocha Nappa | Aluminum Rhombicle | Exec Pkg | Luxury Seating | Bowers & Wilkins | Parking Assistance Pkg | MSport Brakes | Ceramic Controls | Space Saver Spare |
09-14-2021, 05:31 PM | #21 | |
Rep 2
Hello everyone
For some reason my iphone won’t give an ip-address after I connected the ethernet. I also don’t get the ‘renew license’ pop up. All help is welcome. Thanks Quote:
10-01-2021, 10:23 PM | #22 |
452
Rep 859
