10-08-2019, 04:53 PM | #1 |
7
Rep 76
Intercoolers that fit without ANY Cutting
Is the Wagner EVo 1 the only intercooler that doesn't require ANY cutting or does the EVO 2 actually fit? Any others?
10-09-2019, 05:58 AM | #3 |
220
Rep 695
10-09-2019, 06:39 AM | #4 |
BXR
575
Rep 636
I installed the "needs no cutting" stepped VSRF intercooler. I had to cut a corner support out of the passenger side plastic. I was annoyed, but it's not something you would ever see and it's not going to hurt anything.
I've read posts about that same intercooler where people didn't remove any material.
2012 135i M Sport Alpine White
10-10-2019, 09:47 AM | #6 |
2316
Rep 4,341
10-10-2019, 12:13 PM | #8 |
59
Rep 51
I installed the Forge intercooler on my car and it required zero cutting. One caveat, I did remove the flexible shroud that clips in front of the intercooler. I may have been able to squeeze it in, but it would have been a tight fit. It's a non-structural part, and because the Forge unit is larger than the OEM unit, the shroud is less critical to ducting air into the cooler. I suspect trimming this shroud would have allowed it to be more easily used, but I just left it off.
nachob2316.00 |
10-13-2019, 08:37 AM | #9 | |
247
Rep 1,585
Drives: 2011 VO 1M
Garage List 2010 Porsche 911 GT3 [10.00]
2021 BMW X5 SD40i [0.00] 2023 Toyota TRD Pro [0.00] 2011 BMW 1M [9.83] 2014 Ford Raptor [0.00] 2005 Ariel Atom 2 [0.00] 2008 135i SOLD [10.00] |
Also, CSF makes a plug n play FMIC, unsure if cutting is involved, -imported https://www.turnermotorsport.com/p-5...iABEgL-SfD_BwE
///1M #643 of #740
10-13-2019, 10:22 AM | #10 |
2619
Rep 2,819
Drives: e82 1M, f87 M2cs
FWIW, I had ADE install their FMIC. The shroud that directs air to the FMIC was cut perfectly to match the new profile. Nothing else required cutting and the shroud is a separate part that could be replaced if uninstalling.
1M track toy mods: BMS chargepipe, BMS OCC, ADE FMIC, ADE motor mounts, MadDad/Lightweight Ti exhaust, ADE custom oil thermostat/cooler, custom MHD tune, F10 550i clutch, Ohlins R+T, Vorschlag camber plates, M3 'vert FSB with Turner endlinks, Stoptech Trophy BBK.
10-13-2019, 11:01 AM | #11 | |
Thread killer
645
Rep 1,896
https://www.1addicts.com/forums/show....php?t=1655101 |
10-29-2019, 08:49 PM | #12 |
Supreme Allied Commander
3868
Rep 54,430
Drives: F80 M3
