10-08-2019, 10:49 AM | #1 |
13
Rep 89
Ideal tire size
Hey everyone,
I'm looking at getting new wheels and tires as my current setup can't handle the power of the mhd stage 2 tune. Currently I have a square setup 18x8 wheels with 225/40/18 Continental Control Contact Sport. What size tires can generally hold the stage 2+ mhd tune off the line while also giving me at least better traction in wet weather? I'm willing to stagger. I just need more traction with not too much under-steer. I've thought about the 1 series specific Arc 8's with 235 front/ 265 rear. or is 225 front/ 255 rear enough to hold the power of the tuned n54? Thanks. |
10-08-2019, 02:52 PM | #2 |
1Addict
3234
Rep 7,894
I like my 275/35/18 mp4s. Great traction, decent sidewall height for straight line, wet performance is phenomenal.
But you'll need wider wheels and at least a 245 up front which requires more work. 225/255 should be fine.
10-08-2019, 03:12 PM | #3 |
13
Rep 89
Assuming you're running the 1 series specific Arc 8?
10-08-2019, 04:23 PM | #4 |
1Addict
3234
Rep 7,894
EC7 18x9.5et58 rear
10-08-2019, 06:18 PM | #5 |
13
Rep 89
10-08-2019, 06:23 PM | #6 | |
1Addict
3234
Rep 7,894
If you're willing to do the fender work and add negative camber, look into the 18x9et42 with 255/35/18 up front.
10-08-2019, 06:42 PM | #7 |
13
Rep 89
Good call, I'll see what they might have. Did you roll your fenders/add camber? I'm a little concerned about the uneven wear with negative camber as I'm slightly on a budget and can't burn through tires. I don't track it but drive it fairly aggressively on mountain roads nearby.
10-08-2019, 07:05 PM | #8 | |
1Addict
3234
Rep 7,894
That said.. set toe to stock and it'll wear basically like stock. Toe eats tires not camber. My fenders are rolled, slightly pulled and trimmed.
