10-04-2019, 06:57 PM | #1 |
102
Rep 152
Does this charger work well?
Hi,
Want to flash my car back to stock and lock DME (BM3). Last time I did this, I bricked my car in my driveway for an entire day before BM3 was able to help. Don't want that to happen again. Was wondering if this charger works for the Li-On battery on the M4. CTek is on backorder & I cant wait that long as my service is scheduled for Tuesday. Thank you! NOCO Genius G15000 12V/24V 15 Amp Pro-Series Battery Charger and Maintainer https://www.amazon.com/dp/B00PKIBVU0..._nJ9LDb53RRRJY |
10-05-2019, 02:26 AM | #3 |
867-5309
76
Rep 308
Drives: F80 M3 ZCP and E36 328i
I went with this one:
https://www.amazon.com/gp/product/B004LWVEKS And the quick connect: https://www.amazon.com/gp/product/B009MI9JMG Some install pics: https://www.instagram.com/p/B3AY39QAQ-s/ |
dreventador102.00 |
10-26-2019, 12:02 AM | #4 |
867-5309
76
Rep 308
small update/edit.
the tender/charger i referenced works great, but there might be a case where you need one with more power. today i was having my car remoted tuned and i managed to run the battery down, even with the charger connected. the car was on, but not running, for over an hour... i'm now looking at the g26000 |
10-26-2019, 01:35 AM | #5 |
84
Rep 331
I had the Ctek and it works flawlessly.
Then, I found Duracell branded charger in Costco few days ago. They support Lithium battery and priced @$44.99
Past: E82 135i Crimson Red | MPE | MHD Stage1+ | Dinan Camber Plate | LCI Blackline | Bavsound stage 1 | KW Coilover V2 |
Past: E93 M3 Vert Alpine White | Remus Sport Exhaust | Past: F82 Yas Marina Blue Civic M4| MPE V2 | DP | BM3 | Apex FL-5 | MP Part(s) | Current: F87 M2 Competition Long Beach Blue | Completely Stock | |
10-26-2019, 09:47 AM | #6 |
867-5309
76
Rep 308
10-26-2019, 11:49 AM | #8 |
181
Rep 310
I use the Genius G7200 and it works great. If you plan to store your car for any extended period of time, I suggest you do not leave anything plugged in to the OBD port. I made this mistake last winter and ended up buying a new battery in the spring.
10-26-2019, 10:34 PM | #9 |
1061
Rep 1,171
Will it work for the F80? Might go that route.
2018 BMW F80 ///M3
570WHP/578TQ |
10-26-2019, 11:27 PM | #10 |
181
Rep 310
10-27-2019, 12:20 PM | #11 |
867-5309
76
Rep 308
i have a 3.5amp tender/charger and my battery died after a 1~2 hour tune session. just ordered a 26amp tender/charger to avoid any battery-related issues in the future.
order this: NOCO Genius G26000 12V/24V 26 Amp Pro-Series Battery Charger and Maintainer overkill, yes, but it took my little 3.5amp charger a long-a** time to recharge the battery. also, the factory battery in the f8x is not cheap, so spending a little money upfront will save a lot of money in the long run. |
10-27-2019, 01:36 PM | #12 |
181
Rep 310
10-29-2019, 04:46 AM | #16 |
867-5309
76
Rep 308
