09-19-2019, 08:40 AM | #1 |
815
Rep 1,078
Drives: Lots of BMWs
Garage List 2018 M4 Vert [0.00]
2006 Z4M Roadster [0.00] 1995 540i [0.00] 2008 BMW M5 [0.00] 2019 i3 Rex [0.00] 2021 X7 40i MSport [0.00] |
Disable suggested gear for 6MT via Carly possible?
Was trying to find out if you can code out the suggested gear you should be in for the 6MT via carly. There were 2 options I saw last night Gear Shift Indicator 1 & 2, I disabled 1, 2 was already off. But it removed the Gear display completely in the cluster and HUD.
For those not aware, on the 6MT, in the cluster it displays the gear number, on the left side attached to that number it suggests the gear you should be in. Very annoying, just dont want to see the suggested gear anymore/
2008 M5 6spd, 1995 540i 6spd
2018 M4 Vert Comp, 2019 i3 120ah REX 2021 X7 40i MSport, 2006 Z4M 6spd |
09-27-2019, 08:32 AM | #2 |
1837
Rep 6,990
Drives: 15 F80 M3, 22 G01 X3 30i
Try contacting Carly tech support - they should be able to give you a definitive answer.
http://www.mycarly.com
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
