09-16-2019, 05:10 PM | #1 |
140
Rep 1,991
Trunk strut replacement. What a frustrating experience!!
I ordered a set of replacement struts for my trunk. Got them in an figured it would be a 5 min job from all the videos I watched. Boy was I wrong. How in the heck are the metal stays supposed to be removed correctly? Both of the ones on the new structs popped off on one side and could not be put back into position. One of them was bent out of shape trying to pry it off and so went in the trash bin. I then tried to move the clips from the original strut I removed to the new ones. Fail as well. The final result was one new strut in the trash and one on the car (I am still unsure if the clips are fully in place, but I wasn't about to end up stratching my paint messing with them any longer). I would not try that again on my own. Wasted some $$$. Glad I didn't pay for OEM struts. The videos did not line up with my experience at all.
On the other hand I replaced the OEM HID bulbs with newer, brighter units with nary an issue. |
09-16-2019, 06:18 PM | #2 |
11472
Rep 1,798
Drives: E86 3.0si
Garage List '55 Ford F100 [0.00]
'08 Z4 3.0SI [8.50] '66 Triumph TR4A [0.00] '85 Corvette [0.00] '64 Corvette [0.00] '68 Triumph GT6 [0.00] '19 VW Golf "R ... [0.00] |
The clips aren't supposed to be removed. To take a strut off, you just pry up a bit on the clip with a small flat blade and pull. To install, you just push the socket onto the ball...don't even touch the spring clip.
Here's a good video: |
09-16-2019, 09:25 PM | #3 | |
140
Rep 1,991
This is the video I watched: Last edited by chickdr; 09-16-2019 at 09:40 PM.. |
09-17-2019, 08:06 AM | #4 |
dances with roads
4737
Rep 4,099
Dunno if the hood struts are attached in the same fashion, but I had no issues disconnecting those last winter when I did some work on the car. Could there be some little nuance you're missing?
09-17-2019, 10:56 AM | #5 |
140
Rep 1,991
There certainly could be. One discrepancy I see in the videos is the need to pop the clip on the new strut prior to installing them. Some do it some don't. It would be much easier to deal with if they don't need to be loosened before installing.
09-17-2019, 10:30 PM | #6 |
2289
Rep 12,565
Drives: Z4 M, X5, GX460
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.24] |
Have you seen the Pelican Parts write-up? These guys have a whole library of DIYs for our cars.
10-02-2019, 04:01 AM | #7 |
56
Rep 202
I suspect that my trunk struts are not up to snuff, but I actually like them that way. With another Z4 I test drove recently for someone, I had to push down on the top of the trunk lid to get it to close. With mine, I pull down on the handle in the trunk, grab the bottom edge of the lid and lower it by hand. I let it drop the last few inches to latch. No worries of getting scratches in the paint on the lid. No slamming of the lid that may possibly cause a crack in the 3rd brake light.
2006 Z4 ///M, Interlagos Blue/Beige
10-02-2019, 06:40 PM | #8 | |
///Multiple
2992
Rep 4,243
Drives: M4 Coupe | M3 | Z4M Roadster
Garage List 2006 BMW Z4 M Roadster [8.81]
2016 BMW M4 Coupe ( ... [10.00] 2018 BMW M3 (Euro D ... [0.00] 2011 BMW 335is Coup ... [10.00] |
I don't know why the clips on the new struts would have to be popped open as they're designed to just pop onto the small ball joint. I spent more time popping open the clips on the old struts than I did installing the new struts. FWIW, I used the StrongArm 6258 on the Roadster and Beneges on the 335is, both available on Amazon.
The Coupe: 2016 M4 | Sakhir Orange | Black Full Merino Leather | CF Trim | M-DCT | More | ED 5/13/16
The Sedan: 2018 M3 | San Marino Blue | Black Full Merino Leather | CF Trim | M-DCT | ZCP | ED 7/18/18 The Roadster: 2006 Z4 | Interlagos Blue | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12 |
wdb4736.50 |
10-26-2019, 11:39 AM | #9 |
Rep 36
I jus replaced mine last week. I used a very small jeweler's screwdriver to pry the clip up, and the new ones just popped into place. I imagine tapping the screwdriver with a small hammer would give you enough leverage. Mine only needed a little amount of release to disengage the strut - the clip didn't have to pop the entire way.
My new set are by Magneto Marelli, $35 on Amazon. They shipped from Eastern Europe, so a little wait to arrive. |
10-27-2019, 08:07 AM | #10 | |
140
Rep 1,991
