09-15-2019, 08:23 PM | #1 |
Rep 12
Driver and Passenger Restraint System Malfunction
I removed my driver and passenger seats today to clean them, and the carpet underneath, and I forgot that I needed to disconnect the battery. I now have a Driver and Passenger Restraint System Malfunction error. What tools are people using these days to reset codes? I'm not looking to invest a ton since I won't be changing any settings, I just want to clear it and move on at the lowest cost. Dealership isn't an option since I'm in a 2015 and am out of warranty.
I was looking at the C110+ but I'm unclear if the F80 is supported. Thanks in advance. |
09-16-2019, 12:36 PM | #2 | |
4488
Rep 10,473
I have pulled airbags and seats without disconnecting battery in past without an error. Your results might easily vary as people often experience different results depending on some variable. If you are sure of your connection, you can try ISTA to reset as a Dealer would. See the coding thread. Never hurts to call the Dealer, tell them what you did and ask what they would charge for a simple reset. Even think about upgrading your istep level at the same time. |
