GetBMWParts
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Forum > Regional Forums > UK
      09-13-2019, 08:38 AM   #1
SY8
Drives: 3 Series
Guys
I've got a Blackvue Dash cam for front and rear and have stuck the front one to the windscreen as per the adhesive sticker provided in the box.
I've noticed that the front camera is starting to fall slightly out of position as it seems the adhesive sticker provided is not holding onto the windscreen that well and may even be because of the sun on the windscreen melting the sticker abit.
Has anyone used a different adhesive sticker to hold the camera onto the windscreen such as gorilla tape or something similar? If gorilla tape I've got some of the clear double sided tape, any issues with using that to attach the front camera on the windscreen?
Cheers
      09-14-2019, 06:35 PM   #2
SynTom
IAM Roadsmart Fellow
SynTom's Avatar
United Kingdom
48
Drives: BMW M4 Coupé
ebay - 3M Double sided pads in the required size.
A few quid, problem solved. Glass clean the life out of the windscreen before you apply the new adhesive.
      09-16-2019, 08:30 AM   #3
SW6Steve
United Kingdom
94
Drives: F30 330d
I have BlackVue cameras front and rear and not had any problems with them coming unstuck!
I reckon prep is your problem. I used some panel wipe
Buy replacement pads here https://www.blackvue.uk/collections/...-mounting-tape
      09-16-2019, 03:54 PM   #4
t5pilot
t5pilot's Avatar
United Kingdom
978
Drives: M4 CP & S1000 XR
@SY8 out of interest, which fuses did you tap into for power supply & ignition live? TIA
/// BM3 + M-Power ///
      09-20-2019, 04:13 PM   #5
apollo
30
Drives: F82 Sakhir Orange
Fuse 100 for permanent and 143 for Acc both using mini piggy back fuse connectors
t5pilot977.50
      09-22-2019, 05:45 PM   #6
t5pilot
t5pilot's Avatar
United Kingdom
978
Many thanks, much appreciated
f80post
