BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Wheels + Tires Sponsored by The Tire Rack
  TireRack
KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK!
      08-16-2008, 11:09 AM   #1
d_dot
4 * General
d_dot's Avatar
Drives: F12 M6,Audi R8 Lambo Gallardo
Spacer question?
I had some rims on my e46 m3 but when i went to put them on the e92 m3 the rears fit fine and the fronts fit as well but the front rim if it rotates will stop cause it will hit against the brake caliper. what do i need ? is there some sort of spacer or something available for this?
      08-16-2008, 12:19 PM   #2
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000 TT3
Depends on where it is hitting. If it is hitting the front face of the caliper than a small spacer will work. If it is hitting the top face of the caliper then a small spacer probably won't fix that.
King Tut
2012 BMW M3 Individual: Sold lsb.ridedomain.com
1987 BMW 325is SpecE30: spece30.ridedomain.com
2009 BMW M3 Coupe: Sold e92.ridedomain.com
      08-16-2008, 10:57 PM   #3
Radiation Joe
Veni Vidi Vici
Radiation Joe's Avatar
Drives: '11 JB/BBe-6sp-e90
2011 e90 M3-Sold  [8.50]
2003 RS6 - Sold  [0.00]
2009 e90 M3 - Gone  [0.00]
2003 M3 SOLD  [0.00]
old 2002  [10.00]
The stock e46 wheels have an offset of something like 46mm. The e92 has 28mm offset. Your aftermarket (I assume) wheels for the e46 might be as low as et35. You need no less than 10mm spacers. You should use the ones from H&R or even better the ones from Rogue Engineering. Most spacers less than 10mm are not hub centric and should not be used. Make sure your spacers are hub centric.
Be aware. There are a few things you need to know in order to get this right. Your goal is end up with an offset in the front between 25 and 30mm. This means you have to know the offset of your replacement wheels. You have to make sure your spacers are compatible with both your hubs and your wheels. You also have to replace the wheel bolts with the appropriate length for your wheel and spacer combination. If you are not comfortable figuring this out, then go to a knowledgeable tire and wheel store to get it done properly. The last thing you want is broken parts in your front suspension.
Dinan compliment of stuff plus PF rotors and RG63s. Enough for now.
Why, yes. I am an abrasive bastard.
m3post
