08-06-2019, 01:31 PM | #1 |
34
Rep 280
SOLD
Retails for $599.99 plus taxes and fees. Used CSF Race-Spec Oil Cooler - E9x M3 Part#: 8025 The CSF E9X M3 Oil cooler is the latest cooling solution available for the oil system on the S65 engine. Manufactured utilizing the latest in technology, the CSF oil cooler contains densely-packed cooling tubes to provide the greatest surface area for heat reduction in your high-revving S65 engine. Fully TIG-welded cast end tank design vs. OEM mechanically-jointed and tack-welded design for superior reliability & durability Turbulated heavy-duty bar/plate design for the most reliable and durable oil cooler available for the E9X M3 8 rows of cooling (2 more than stock) with a high-density multi-louvered fin pitch design Drop-in fitment requiring no modifications to install. Accepts all standard attached OEM components including oil-line connections, mounting brackets, and shroud/ducting Tapered cast end tank design fits precisely with the contour of the OEM bumper Allows fitment of most aftermarket splitters Motorsport silver finish Last edited by riccio; 11-09-2021 at 08:58 AM.. |
08-07-2019, 05:12 PM | #3 |
34
Rep 280
I purchased this one from a forum member and didn't install it because I ended up getting a D088 kit (more expensive). I trust his judgement and he said it significantly improved cooling. It's a must have.
