08-01-2019, 10:34 AM | #1 |
523
Rep 631
KW v3 vs. HR VTF
spacejamm_x5m's recent post about his highly modded (and amazing) ride got me to thinking about KW v3 vs. H&R VTF. I have read many of the posts disappointed with stiffness/bounciness/etc. with any and all non KW systems (admitting that not everyone feels this way). However, does spacejamm's disclosure that bump stops play a big part in the overall ride quality change anything?
I will honest with you guys: a significant reason for my curiosity is cost. I am sure the KW system is superior but perhaps by removing or shortening the bump stops the two systems are not as far apart as some might think. Thoughts? |
08-01-2019, 11:00 AM | #2 |
Self-Deprecating Narcissist
7266
Rep 6,561
KW V3. Shock and coil paired from the factory without modification or removal of other components to achieve the desired results.
08-01-2019, 11:16 AM | #3 |
Living the dream
4588
Rep 2,194
Drives: X5 w/MPPK, MPE & RC GTS Black
I believe that daytonaviolet installed the HR VTF then swapped to KW V3. He would be a great member to speak with about this.
Gtz1wickedest646.50 |
08-01-2019, 12:05 PM | #4 |
523
Rep 631
It was actually daytonaviolet's post in another thread that got me to thinking about this. It was in that thread that he said: "So did you take them [bump stops] out completely or just cut them down to size. Perhaps I shouldn't of tried this before getting kw 🥴"
Violator4587.50 |
08-01-2019, 03:26 PM | #5 |
2311
Rep 12,654
The VTF kit comes with it's own bump stops, the ride quality is definitely a bit rougher with more roll on the spring kit versus KW V3.
08-01-2019, 06:23 PM | #6 |
213
Rep 607
Sorry to hijack is the coil over appropriate for winter driving?
2017 F86 X6M
2014 F10 M5 2015 F85 X5 M 2015 F86 X6 M (Retired) 2014 F10 M5 (Retired) 2010 E70 X5 M (Retired), 2010 E92 M3 MT (Retired) 2006 E60 M5 (Retired), 2000 E39 M5 MT (Retired) 1999 E39 328i (Retired), 1995 525i (Retired) 1987 325i (Totaled - that was fun!) |
08-01-2019, 10:44 PM | #8 | |
OEM CSL Whore
1250
Rep 1,476
I've read about others using the dinan bump stops as they were shorter. But I never experimented with cutting or completing removing the stops. 🤔 |
08-01-2019, 10:54 PM | #9 |
12971
Rep 18,716
Bounciness is all depending on the car's owner.
I personally think E70 X5 ride quality was perfect, but most are saying that it is too stiff. Some says the F15 X5 / F85 X5M suspension is too soft, some says it is harsh. In this subject, it is very hard to compare someone's feedback to your personal preference. Overall, after installing many2 suspension, so far the best road coilover is KW V3. Is it my cup of tea, to tell you the truth, no. I prefer a more aggressive suspension even for my street car. H&R VTF, some do like it, some don't. Some says it is bouncy, some don't. It is all depending on how low is your setup. Bump stop wise, it is a safety feature in the damper. If you goes too low, you are pretty much riding on a bump stop, which is technically a very high rate spring. If you are sure that you won't overload the car or going over a dip or bump in a high speed where it will cause the shock to max bottom, then yes, you can run without it.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
daytonaviolet1250.00 Phara107.00 |
08-01-2019, 10:54 PM | #10 |
12971
Rep 18,716
It doesn't comes with bump stop.
08-02-2019, 04:25 AM | #11 | |
2311
Rep 12,654
My bad |
daytonaviolet1250.00 r33_RGSport12971.00 |
08-02-2019, 06:29 AM | #12 |
523
Rep 631
Thanks for all of the responses. Not sure what I will do. I typically ride in sport+ and think the ride is fine. It would be great to go with VTF due to cost but I think I would prefer KW. We will see. Thanks again.
08-18-2019, 02:02 PM | #13 |
107
Rep 52
Installed H&R sport springs and links. Didn't like it at all. Installed KW var 3 this Saturday. It's a miracle, car is lowered now, and rides almost perfectly. Will make littles adjustments tomorrow and quite sure it's going to be perfect
iconoclast7265.50 KCTiger522.50 |
08-18-2019, 02:38 PM | #14 |
523
Rep 631
iconoclast7265.50 |
08-19-2019, 07:41 AM | #15 | |
107
Rep 52
Front Bump 6 Rebound 6 Rear Bump 6 Rebound 9 |
daytonaviolet1250.00 |
08-21-2019, 10:46 AM | #17 |
107
Rep 52
Went through all thread, saw your settings, contacted KW office in Germany, they also confirmed factory settings are the best for everyday usage
08-22-2019, 09:18 AM | #18 |
523
Rep 631
Looks like Phara and Kruppa use similar settings. I think daytonaviolet is -6 all around, not sure about desertfox73.
If any of the folks knowledgeable about this system feel like indulging me, a few questions: 1. How easy it is to adjust the bump and rebound? Must the car be on a lift? 2. Same question but related to amount of drop. Easy? On a lift? I think most folks went with max drop but maybe that is a faulty assumption. 3. Did anyone require a "camber kit"? Not sure if that is even a term but I thought some folks might need to adjust camber. 4. Were multiple alignments necessary or just one? How long after the install was the alignment performed? I just re-read Kruppa's thread and if this info was in there, I missed it. Thanks all. |
08-22-2019, 03:01 PM | #19 | |
OEM CSL Whore
1250
Rep 1,476
inline
KCTiger522.50 |
08-22-2019, 03:07 PM | #20 |
523
Rep 631
Thanks a ton DV! Every pic I have seen of your ride looks great so I might go for a similar drop when I pull the trigger. Getting close on a few projects at work that were the self-imposed milestones before I can pull the trigger. Thanks again
08-22-2019, 03:31 PM | #21 | ||
107
Rep 52
08-22-2019, 03:50 PM | #22 | |
OEM CSL Whore
1250
Rep 1,476
so i need to make an appointment. sometimes one side will settle more then the other. |
