07-26-2019, 05:16 PM | #1 |
21
Rep 166
Gts dct flash
what are the features? Do you think its worth it ?
07-27-2019, 11:51 AM | #2 |
867-5309
76
Rep 308
Drives: F80 M3 ZCP and E36 328i
is it part of bootmod3 or a different product?
07-27-2019, 10:27 PM | #3 |
298
Rep 584
I flashed the GTS coding for my DCT, differential, steering, and DCS with Thor about a month ago. It definitely improved it's behavior at lower speeds though it's still not what I'd call silky smooth. It also increases clutch clamping pressure which is good if you've got more power than stock. I consider the whole package to be worth it.
07-28-2019, 06:16 PM | #4 | |
867-5309
76
Rep 308
found a better answer here (MHD tune):
https://f80.bimmerpost.com/forums/sh...&postcount=204 Quote:
07-29-2019, 07:22 AM | #5 |
BimmerPost Supporting Vendor
1790
Rep 3,056
It’s not manufactured by bootmod.
It’s original BMW TCU tune for M4 GTS version. Since standard M4 uses the same hardware as M4 GTS, we are able to flash TCU(Transmission ECU) to GTS software to get faster shifts, less jerky on low gears and more. |
TheirThere76.00 |
