07-17-2019, 12:39 PM | #1 |
124
Rep 238
Drives: 2015 M3
Mystery Used M3 Coding
I bought a 2015 F80 5 days ago.. dealership buy so no previous owner information.
Loving the car so far but over the past few days I've noticed a few things that are obviously not stock where the previous owner has coded some things. - GTS Logo on dash when starting up - Door open sound is not typical gong noise - No seat belt warnings - 5 flash blinker instead of 3 - Fold up mirrors I like all of these things and don't care one way or the other - here is what concerns me: - Vehicle is equipped with EDC but it is coded out completley, doesn't even show up on dash. - After checking for coilovers/springs, it has KW HAS which should retain factory EDC, and the EDC plugs were just tucked away. - Reverse lamp malfunction/No reverse lights (this could be due to a number of issues other than coding - Sideview camera malfunction (they both come on when you activate for about 2 seconds then one turns blue and it disappears, not as concerned about this as I had it on my M5 and never used it once) Out of all this, what I would really like back is EDC, did he have coilovers with the delete and was then too lazy to recode-plug back in after? Is there something wrong with the EDC? How can I code it back in? If I take it to the dealer and ask them to reset the car, how much are money are they going to suck out of me? (car is out of warranty). Could there be more errors or codes being hidden by the code? Any advice or direction would be greatly appreciated! I'm not afraid of doing some coding/uncoding myself if there is a good way to check for these things - while I haven't done coding for BMWs, I am an engineer with software exp. and am willing to learn given the right direction. |
07-17-2019, 01:25 PM | #2 | |
BimmerPost Supporting Vendor
8215
Rep 18,823
Drives: BMW
You'll need someone to remote code to fix everything or return to a clean slate. EDC computer is likely unplugged also. Dealer can help, but will likely need to open a PUMA case as the VO needs to be modified.
_BSMM5123.50 |
07-17-2019, 01:33 PM | #3 |
136
Rep 453
You just bought it. Have them undo the coding back to the defaults. You want to start clean coz who knows what other things the previous owner did to the car. EDC will probably fault right off the bat, but you know what it is about so you can deal with that separately.
_BSMM5123.50 |
07-17-2019, 02:18 PM | #4 | ||
124
Rep 238
Drives: 2015 M3
Any reccomendations on who can do a clean state? I'd rather stay away from the dealer unless they have something I absolutely need. Quote:
07-17-2019, 03:05 PM | #5 |
8215
Rep 18,823
Drives: BMW
Try the regional section to see if someone is nearby.
07-17-2019, 03:07 PM | #6 | |
124
Rep 238
Drives: 2015 M3
What about remote? |
07-17-2019, 03:46 PM | #7 |
124
Rep 238
Drives: 2015 M3
Also just realized my tailights are LCI tailights. Didn't part those out, but must've not coded them completely.
07-18-2019, 02:31 PM | #8 |
8215
Rep 18,823
Drives: BMW
Replied to your email. Sorry, I don't code remotely.
07-20-2019, 02:10 PM | #9 |
124
Rep 238
Drives: 2015 M3
No worries,I recoded it. It was pretty simple, thanks for the response!
07-21-2019, 12:17 AM | #10 | |
4490
Rep 10,473
Most reputable Dealers inspect the car to find issues prior to putting them up for sale from a simple liability standpoint. Actually, the Dealer simply has to update the iStep for your car and it should reset everything and return everything to factory settings. Most Dealers charge less than $300 for this - but I would suspect they would do this for free as you just purchased. That should also eliminate any other gotchas you have not found. |
