GetBMWParts
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > DIY and Coding Discussions
      07-07-2019, 03:47 PM   #1
geeuk
Drives: 335d
chassis function restricted after cs vdc vo code
hi all,
I have vo coded my f82 to the cs vdc/edc i am getting the "chassis function restricted" error on the dash and I think I need to calibrate my sensors.
I started the test plan "EDC: Start up" but when i proceed with the plan it says the faults remain and faults needs to be fixed in order to calibrate.
I am using Ista+ 4.10.20.
Any advice please?
Thanks,
Gee
      07-08-2019, 09:23 AM   #2
geeuk
Drives: 335d
Solved
Anyone that has the same issue as me, please check your fa list specially the salapa and make sure you remove the 7MA and 7MN (competition pack options) as coding with these would the above cannot reset problem on insta as in conflicts with CS or COMP data.
Such a simple error and it makes sense but if you don't have experience it can be hardest thing to figure out! we learn everyday
Appreciate 2
      07-14-2019, 07:42 AM   #3
Trevorstein
Trevorstein's Avatar
150
Drives: Trabant
"Help!"
*https://f80.bimmerpost.com/forums/sh....php?t=1633807
I didn't want to hijack your post.
Cheers!
///M Joy
f80post
