07-02-2019, 01:42 PM | #1 |
Rep 11
Looking for advice! Rim Specs
Hey guys! I'm looking into getting rims on my 1er. There is a set of advan racing rims available and the specs are :
Front 18x8 et45 - 225 Rear 18x9 et50 - 245 Would this fit my car? I am lowered in springs and my OEM 18inch fit fine right now. |
07-02-2019, 03:54 PM | #2 |
1Addict
3234
Rep 7,894
Depends on the sidewall ratios of those tires. The wheels will fit fine and offsets will be really nice. Mine are 19x8et45 and 19x9et48 for reference and I use 265/30 rear tires out back.
You could certainly go for 225-40-18 and 255-35-18 tire setup, get yourself clearance with camber and a mild fender roll or trim and you'll be guaranteed never a peep.
fuzey134.50 |
07-03-2019, 07:10 AM | #4 |
369
Rep 324
People generally go with either
215/40/18 and 245/35/18 (OE for 135i) or 225/40/18 and 255/35/18 These combos match the front and rear overall tire diameter the closest. But you may run into some issues with being lowered and the 255 rear (but maybe not) If you really want to dig deeper, this is my favorite wheel and tire size calculator: https://www.rimsntires.com/specspro.jsp Plug in your new and old wheel and tire dimensions and it will tell you how much more the tire will stick out. Then go examine your current setup and see if you have room Last edited by Fakemike; 07-03-2019 at 07:19 AM.. Reason: Added Tire Size Comparer |
fuzey134.50 |
07-03-2019, 02:49 PM | #5 |
2042
Rep 25,989
Those specs will work perfectly on the 1 Series. Tire sizes should be 225/40/18 for the front and 255/35/18 for the rear. This shouldn't cause any rubbing or require any modifications.
fuzey134.50 |
Tags |
#rims |
