      06-30-2019, 10:31 PM   #1
fuzey13
Drives: BMW 1351 /N54
XXR 521
Wondering if the xxr 521 would fit on a 135i and if it would look good?
      07-03-2019, 02:56 PM   #2
VMRWheels
VMRWheels's Avatar
2042
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
Looks are subjective so get what YOU think looks good on your car. In order to confirm whether they'll fit, we'll need specs. (diameter, width, offset)
      07-03-2019, 10:12 PM   #3
irontitan
Drives: Ford F-150, BMWX5
Have you made a decision?
      07-04-2019, 09:14 AM   #4
Fakemike
Fakemike's Avatar
369
Drives: 135i N54 MT
2008 135i  [0.00]
No, the offset is too low. A 135 needs an offset around 45mm to 55mm for that wheel width
XXR 521 18x8.5 Flat Black 5-114.3/5-120 [+25mm]
XXR 521 18x10 Flat Black 5-114.3/5-120 [+25mm]
      07-04-2019, 10:25 AM   #5
fuzey13
specs are 18x8.5 front and rear. 245 in the rear and 225 in the front
      07-04-2019, 01:42 PM   #6
deesea
60
Drives: 2009 135i
Need to know the offsets to confirm. If it's only offered in ET25 it'll be tight.
It'll be aggressive as all heck, you could try to knock out the alignment pin up front and max the camber if you don't have M3 arms, camber plates, and etc.
On stock suspension, the rears on a 245 will likely need to max the available camber (if you don't have adjustable toe links, I'm not sure what your max camber will be). might be better off running a 235 section narrow rear tire, and dial in as much camber as you can.
      07-05-2019, 10:23 AM   #7
fuzey13
Details
Bolt pattern: 5x120
Size (front): 18" x 8.5" ET35
Size (rear): 18" x 10" ET19
CB: 74.1mm
      07-06-2019, 12:12 AM   #8
deesea
60
Drives: 2009 135i
Et19 and 10 inch rears will be impossible.
Tags
#135i, #wheels, #xxr
