06-20-2019, 02:59 PM | #1 |
58
Rep 214
Zcp exhaust on civic f80
Will this throw and error codes? Any different than regular f80 exhaust besides the black tips? I know I won't get the burbles due to non zcp tune. Cheers
06-20-2019, 04:04 PM | #3 |
58
Rep 214
Have full akra turbo back already. Is that proper enough for you. Asking due to maybe trading in car soon and will put stock or zcp exhaust back. Whichever's available. Cheers |
06-20-2019, 10:11 PM | #6 |
2889
Rep 2,147
Since you said you have a turbo back, I'm sure you already know you'll need stock cats. I don't think the part numbers are any different for base vs comp pack. Cat back is the same except rear muffler internal design. But I wouldn't worry about it, nobody will notice the difference unless it's pointed out. I'm still not convinced the comp pack sounds any different, it's just placebo effect from the burbles. Even if it did most people would consider it an upgrade. Find whatever you can easiest and quickest.
06-21-2019, 06:35 AM | #7 |
197
Rep 710
Just a thought, there were two OEM non-ZCP exhaust FS that may be ideal, but location may negate that and not sure if you already have the ZCP exhaust. This is coming from a prick outside of NY because as you may be aware, the only difference between a porcupine and a BMW driver is the prick is on the inside
