06-14-2019, 05:50 PM | #1 |
BMW Master Tech
587
Rep 850
Drives: E30, E36, E82, E90, F10, F80
Garage List 2015 Aston Martin V ... [0.00]
2010 Lamborghini LP ... [0.00] 1985 Alpina C2 2.7 [0.00] 2017 BMW M3 [0.00] 2008 BMW 128i [10.00] 2013 BMW 135is [0.00] 1992 BMW 325i [0.00] |
JB4 Install - Starts then dies.
Hey all,
So I bought a JB4, and installed it and attempted to start the engine. It cranked and cranked and would catch for half a second then die. It smelt like it was running rich, and a decent amount of smoke was coming out of the back. I then disconnected the fuel rail pressure sensor from JB4 harness, and plugged it back into the vehicle's harness. It ran perfectly, but with pending fault codes. I eventually just decided to disconnect the whole thing until I figured it out. The only stipulation is that everything was connected, except for the CAN/OBD part, as it didn't come with the kit (on order). Does anyone have any insight? Maybe the JB4 isn't getting enough power? I didn't plug in any 12v source, so maybe that was it. But I don't know these JB units very well, and their DIY PDF seems to be down. Thanks for any input!
135is #502 of 586
BMW LED Performance Wheel | OEM FULL Carbon Fiber | E9X M3 Gauge Cluster | E9X Exterior Mirrors | E9X M3 Full Suspension | E9X M3 Diff | PT-CAN2 Enabled | Bilstiens | Michelin PSS's | NBT Navigation Retrofit with Touch Pad |
06-14-2019, 06:31 PM | #2 |
550
Rep 949
Install guide should be posted on their product page: https://www.burgertuning.com/product...-m3-m4-s55-jb4
Why don't you have the OBDII? Maybe you have the wrong unit or a firmware issue? Maybe something is loose in the harness or damaged? |
