06-12-2019, 02:57 PM | #1 |
68
Rep 92
SPORT+ Engine Setting and damage
So,
I have read in places that running the car in SPORT + for the engine setting keeps the turbos spooled longer to decrease lag time and increase throttle response. Is there any truth to this? If so, when running with a tune, will driving around in this mode adversely affect the engine longevity? Thanks!
Rides--
'17 M3 CP-CAI, Dinan Stg 1 '17 Camaro ZL1 (700HP) '15 Audi S4 (500 HP) '15 Charger Hellcat (1050 HP) |
06-12-2019, 03:49 PM | #2 |
On the road to serfdom
1392
Rep 673
Drives: 2018 F80 M3 DCT, 2019 Raptor
Yes, Sport+ keeps the turbos spooled. Turning faster longer will probably result in some incremental wear, though is doubt it would be significant in terms of longevity.
I’m tuned and drive in Sport+ 90% of the time. I don’t see the point in having a car like this if I’m not going to enjoy it’s full potential when I daily drive it. I want that power and responsiveness on tap whether I get the opportunity to use it or not. So I don’t worry about any incremental wear I’m putting on it.
"God bless our troops...Especially our snipers.”
11
shay2nak1070.00 Laoschris491.00 MisterF80M31047.00 TideMD291.50 ShoNufff79.00 ra2289305.50 kim@supremepower73.00 behindthen0thing839.50 Alpine_F82215.50 chetrickerman10442.00 PhatLyfe985.00 |
06-13-2019, 02:47 PM | #4 | |
1392
Rep 673
https://www.bmwblog.com/2014/04/23/b...-3-new-engine/ “In the SPORT and SPORT PLUS modes, the waste gates remain closed under partial load and the mass flow is routed through the turbines, to ensure that the turbo chargers are already rotating at a higher base speed even in standby. Moreover, certain special engine control functions are brought into play that accelerate activation of the turbo chargers. This means that the car responds more closely to the accelerator in SPORT and SPORT PLUS modes.”
06-13-2019, 10:02 PM | #6 |
10740
Rep 3,690
Don't stress. The amount of additional wear is negligible and no one in their right mind would ever even begin to quantify it to you since there are so many factors involved. Your biggest enemy will always be heat.
06-14-2019, 08:56 AM | #8 |
5450
Rep 8,815
I'm usually in Sport 99% of the time. When I switch to Sport+ the difference is very noticeable compared to Sport.
More part throttle boost/power Immediate response Way more intake/blow off sounds from my Eventuri Intakes (ASD turned off so its not fake) Lots more burbles (This is the only thing I dislike about this mode) Engine fans stay on longer and lower the oil temps a significant amount (designed for track use but benefits from super hot summer days too) No more rev matching in Sport+ (recent builds still rev matches) In general the difference in wear is negligible. The difference would be more between someone constantly full throttling the car vs normal driving than sport vs sport+ imo. Alan
06-14-2019, 09:27 AM | #9 |
#LSBM3
1420
Rep 1,973
Drives: 2016 BMW M3
Garage List 1984 BMW R65 [0.00]
2020 Ford F-150 XLT ... [0.00] 2003 Mitsubishi Evo ... [0.00] 2016 M3 Competition ... [10.00] |
Sport+ or nothin'
/// M3 |
06-14-2019, 09:43 AM | #10 |
515
Rep 554
Drives: 2018 M3 ZCP 6MT
06-14-2019, 09:58 AM | #11 |
48
Rep 92
I don't understand the draw of driving in sport+ all the time, the throttle is an on/off switch at that point. If you encounter any stop and go traffic, even a little bit, I find it wholely unplesant due to the already jerky nature of the DCT at low speeds which is 10x worse in sport +.
To each their own but I think its probably the least used setting/mode in my car. |
06-14-2019, 10:12 AM | #12 | |
2889
Rep 2,147
06-14-2019, 10:22 AM | #13 | |
2050
Rep 6,110
I remember this being a heavily advertised feature when the car was coming out (in order to help people who were crying about losing an NA motor).
When you say impact instead of affect/effect, you are communicating that you don't understand the difference between the two words, and are too lazy to learn.
06-14-2019, 10:35 AM | #14 | |
1392
Rep 673
behindthen0thing839.50 |
06-14-2019, 10:40 AM | #15 |
46
Rep 211
I think this depends on preference a lot. I drive s+/s+/s/d3 most of the time. When I'm in bumper to bumper traffic under 20mph, then I'll switch to s/c/c/d2.
06-14-2019, 01:19 PM | #16 |
1582
Rep 1,976
I love using sport plus when I’m driving on the open freeway (not in traffic) or canyon cruising, BUT I use sport and sometimes even efficient on the track due to the twitchy throttle. You can be smoother with the car.
In regards to the higher modes causing wear, probably? Esp since you’ll be driving it harder? |
06-14-2019, 02:01 PM | #17 |
21117
Rep 20,741
Drives: 2021 911 turbo
A small related anecdote:
At my last track event, my car suffered from “chassis restricted function” error due to a faulty strut accelerometer. When the fault appeared after one or two laps, the EDC would default in full stiff and the engine in Efficient. DSC could still be switched off (although MDM was unavailable) and the DCT could be put in S3, so I kept driving it for the remainder of the two day event despite the limited EDC and engine functions. I can now without any doubt say that Efficient is significantly damped and non-linear and completely sucks for track use. At high RPM, the power can only be found in the last quarter inch of pedal travel and there is significant lag with the delivery of power, which makes it quite unpredictable.
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
06-14-2019, 05:41 PM | #18 | |
362
Rep 1,206
behindthen0thing839.50 ///M4TT150.00 |
06-14-2019, 07:13 PM | #19 |
38
Rep 59
Drives: 2018 M4 with Comp Pack
I agree with this thought. In my mind, efficient is only for those times I need to close the exhaust valves (i.e. wife).. Sport is totally useless and I can honestly say Ive used used it only to see if it works. lol Efficient is awful in terms of pedal response as far as Im concerned. So sport+ it is for me. I don't find the car jerky in sport+, perhaps Im good with a clutch? I simply wish (without getting a tune) that I could shut off burbles (most of the time), shut off rev matching in all modes and simply control the exhaust flaps(and perhaps lessen the burbles) as I desire WITHOUT getting out of sports +. Yeah I can get a tune to do that, but then I have to worry about warranty etc. It's a leased car, so Im not going to put any money into the car. Some of BMW's decisions were not to my liking.. obviously. Still love driving the car (in sports+) lol
06-14-2019, 08:08 PM | #21 |
840
Rep 937
I used to drive in sport + all the time, until I've fully decatted the car. Now it's kinda ridiculously loud.
I have to use the efficient settings just to make the car quieter in the neighborhoods. Germans hate loud noises. I've had people follow me, video my car, leave notes on my car, yell things through the windows, shake their fists as I drive by, etc. If my car wasn't so loud I would also be in s+ all the time. The car drives so much better that way. Sport is useless in my opinion. |
06-14-2019, 08:19 PM | #22 |
18’ F82 ZCP
150
Rep 162
That's like choosing to play a little game called just the tip.
2018 F82 ZCP MGM
