ARMA SPEED
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Engine / Drivetrain / Exhaust / Bolt-ons / Tuning
      05-30-2019, 10:37 PM   #1
UsAs
UsAs's Avatar
Germany
Drives: BMW M3 F80
Question Boost pressure on tuned F80 M3 too low, missing hp
Hey folks,
i need your advice.
I have an M3 F80 (2015), 26000 miles on it. The car has mounted bigger chargepipes, akrapovic downpipes, has oem exhaust and pipercross airfilter.
It got a new software this week and dyno run.
Output should be around 550 to 560hp and around 750nm.
We got 510hp and 780nm at the dyno run. Many runs, no more output power. Torque is over the top (30nm more than normal), nearly 50 hp are missing (we don't know why).
Tuner adjusted boost around 1,7bar (24,65psi), logged output is a max of 1,5bar (21,75psi) at full throttle in mdm mode.
Do you have any advice?
We dismounted the whole air intake and chargepipe section a few times, we couldn’t find any failure. Car is running good in normal driving, but power is missing.
Faulty turbos or wastegates? There isn’t any other point i could find. Wastegate is operable through tester but it may have too much clearance and boost is leaking?
Thanks for any advice, appreciate your help.
Greetings from the home oft the ///M power, germany.
Cheers, seb
boost is all you need
      05-31-2019, 04:31 AM   #2
scoobyhummel3
scoobyhummel3's Avatar
China
69
Drives: Mica White F80 M3
by any chance you could share the dyno graphic with us? and which gear it was when you did your dynorun?
TPE Stage 1 Tune
485 whp
513 lb-ft wtq
instagram: scoobyhummel
      05-31-2019, 05:06 AM   #3
UsAs
UsAs's Avatar
Germany
Drives: BMW M3 F80
Fifth gear dynoed. Did a second run today, 500hp, 714nm torque. Still missing power. Bad S55.
Did a compression test a few minutes ago, everything normal.
      05-31-2019, 05:36 AM   #4
Zero_Cool
Zero_Cool's Avatar
191
Drives: 18 M3 Imola 6spd
Where are you doing the dyno pulls?
      05-31-2019, 05:54 AM   #5
ShoNufff
Who's da masta?
ShoNufff's Avatar
Drives: M4
Can you post the dyno sheet? Also what new software are you running?
      05-31-2019, 02:37 PM   #6
shay2nak
smoke if ya got 'em
shay2nak's Avatar
Drives: F80 M3/Lotus Exige/500 Abarth
Did you do a baseline pull? Maybe the dyno reads low.
      05-31-2019, 06:42 PM   #7
TrueNorthM5
118
Drives: 2015 Alpine White BMW M3 (DCT)
Take it do a drag strip or log some 100-200 runs with a Dragy or Vbox.
Dynos are only truly useful for tuning and without a baseline numbers are meaningless.
P.S. 500 wheel hp on a dynojet sounds about right for your setup to be honest. Should trap around 123-126mph in the 1/4
Currently: '15 M5 (dct) BM3 STG1 11.3@128 Spinning /// '11 X3 35i 13.9@99/// '02 Transam 12.7@112
Previously: '15 M3 (dct) BM3 11.58@126 /// '13 Cadillac CTS-V 11.9@115 /// '12 128i /// '08 Benz c300 6spd
      03-12-2021, 12:31 AM   #8
Magic M4
Magic M4's Avatar
48
Drives: F82
Any update , I am having the same issue
      03-12-2021, 07:16 AM   #9
TopJimmy
TopJimmy's Avatar
Drives: 2023 M3 Comp xDrive
Need a log. A dyno sheet helps, but the log is needed.
'18 F80 Base 6MT | '19 F82 Exec DCT | '18 F82 Comp Exec DCT | '23 G80cx
      03-12-2021, 10:30 AM   #10
Chris@VargasTurboTech
1933
Drives: All Things TurboCharged
Log & dyno sheet would be great.
      03-13-2021, 10:56 AM   #11
Magic M4
Magic M4's Avatar
48
Drives: F82
Curious to see if you are comp or non comp
IG: immigrant_racing_league
      03-13-2021, 11:11 AM   #12
chewbakam4
chewbakam4's Avatar
717
Drives: F82 M4
+1
      03-13-2021, 11:15 AM   #13
ALCOBENDAS
94
Drives: M3 F82
When we mounted the TTE to my M4 something similar happened to us .. the pressure was missing .. the mechanic did something with the ista, I reset the wastegates and everything was perfect
      03-16-2021, 11:08 PM   #14
Magic M4
Magic M4's Avatar
48
Drives: F82
Figured it out , my issue was the aftermarket intakes, swapped back to oem
With drop filters and no more problems
Appreciate 2
Tags
bmw, bmw m3, f80, turbo, wastegate
f80post
