05-30-2019, 09:10 AM | #1 |
38
Rep 141
Sport Mode and Steering Changes
What exactly changes when you select Sport Mode in the steering? I am on a 2014 X5 F15 50i.
I have an issue were the car wanders on hwy speeds, requiring frequent correction and it just overall feels loose. It is almost like the tires are overly sensitive to minor road grooves and it keeps pulling, except the road surface is fine. In lower speeds everything seems fine. Alignment was recently done. Turning the wheel back and forth in a parking lot, you can feel that the rotation/movement is not linear, it seems a little square and feels a tad bit odd, hard to characterize. Seems to be better in the Sport mode, so curious what changes that makes the steering better. My steering did bind and not return to neutral and the rack was replaced, the steering has felt worse in terms of this instability than before, just wondering if the fawlty rack was actually giving a better feel and this is normal for this vehicle. |
05-30-2019, 09:19 AM | #2 |
///M
193
Rep 272
Drives: 2015 F15 X5 50i M Sport
It's electric steering. Sport Mode tightens up the steering feedback as well as chassis/suspension if you have M Adaptive or DHP. Can also adjust how long the transmission holds gears and throttle response if you have that selected. I think steering is a little loose in comfort too.
Frequent correcting on the highway is most likely due to the "ruts" "grooves" from thousands of cars traveling in the same path - our wide tires tend to "float" over these ruts/grooves. Try to test out on a freshly paved highway if you can. It should glide just fine without the need to correct if your alignment was recently done and tires are balanced and in good shape. Highways also have a slight grade to either side for water drainage.
2015 F15 X5 xDrive50i - M Sport - Space Grey Metallic - 21" 612M - Accelera Iota ST68's - Black Dakota - Leather Dash - Poplar Wood - Ceramic - Shawdowline - Anthracite - Adaptive M - Full LED - Executive - DA+ - Surround - HUD - Enhanced BT - Soft Close - B&O - ACC Stop & Go - Multi Contour - 4 Zone Climate - Comfort Seats - Cold Weather - Muffler Delete - Akrapovic Tips - F85 Grille - 35% Tint - BMW All Weather Mats -- Missing DHP, NV, Active Steering, Rear Entertainment, & Cooled Seats
05-30-2019, 10:26 AM | #3 | |
4145
Rep 7,160
Drives: F90 M5 / F15 50i
Also yes our steering sucks. It's impossible to keep center which causes my wife to constantly feel like she needs to critique my driving.
'07 Yamaha R1 (sold)
05-30-2019, 10:28 AM | #4 | |
38
Rep 141
05-30-2019, 10:30 AM | #5 |
38
Rep 141
It was floaty and not precise before, but after the rack was changed I keep thinking something is about to break.
05-30-2019, 10:56 AM | #6 |
843
Rep 1,497
CanadianLurker41.00 Maverik2594144.50 |
