      05-27-2019, 10:52 AM   #1
Marvelousone
Marvelousone's Avatar
9
Drives: 2009 135i
Exclamation Weird Broken Speedometer - What are my options?
Ok, another weird one here:
About 9 months ago, my speedometer on the cluster of my 09' 135i started acting up. Basically, 'zero' is now anywhere between 160kph and 250kph depending on the day (changes every time I start the car), and as I drive, the needle goes up as expected until it literally hits and ticks against my fuel gauge.
Never been in an accident or anything that would contribute to a strange issue like this.
Has anyone seen this before, and if so, is there anything I can do to fix this?
Also, I am in Toronto so if the conclusion is that there is nothing I can do, then any suggestions on where to get it fixed would be much appreciated.
Thanks,
Marv
2009 135i AT / CF Trim / ACS Pedals / Alpine HID 7000K / ST Coilovers / BMS DCI / VMR v701 18"/215/40 18"/245/35
      05-29-2019, 11:45 AM   #2
dtla1
dtla1's Avatar
828
Drives: 2011 135i, Space Grey
Thanks,
Marv
I know the JB4 has a function to reset the guages, and if I remember correctly you can also calibrate via NCS Expert
      05-29-2019, 01:54 PM   #3
JimD
JimD's Avatar
368
Drives: 128i convertible
I don't know how to fix your gauge but I have noticed others saying they changed gauges so getting a cluster from the wrecking yard might be an option. I do not use my speedometer, however, because it is inaccurate. I enabled the digital speedometer that you see where you can get average or instantaneous mpg. The M cars have it and you can too. But you have to code it in. You can remove the BMW "Korrectur" from it, I don't know how to do that to the normal speedometer. The option to have it is something like "B_DIGITAL_V" and the high reading can be removed with a command like "B_DIGITAL_V_KORREKTUR". My notes indicate I set both to "activ". I used NCSExpert which you can get from Bimmergeeks.
128i Convertible, MT, Alpine White, Black Top, Taupe Leatherette, Walnut, Sport
Ordered 5/22/09, Completed 6/4/09, At Port 6/9/09, On the Georgia Highway 6/13/09, Ship Arrived Charleston 6/24/09 at 10pm, PCD 7/21/09
      07-19-2019, 09:03 AM   #4
Edrift
Australia
75
Drives: BMW 135i E88
Simple and cool looking work around is to buy a heads up display unit off eBay. It plugs into your OBD2 port and projects the digital speed on to your windscreen.
Only cost me about $A25 delivered.
