View Poll Results: / OIL DECISION / F80 / F82 / F83 / | |||
0W-30 | 19 | 19.59% | |
0W-40 | 38 | 39.18% | |
5W-30 | 20 | 20.62% | |
5W-40 | 18 | 18.56% | |
OTHER | 2 | 2.06% | |
Voters: 97. You may not vote on this poll |
05-26-2019, 09:28 AM | #1 |
18
Rep 46
Oil decision : 0W-30 vs 0W-40 vs 5W-30 vs 5W-30
What oil are you recommended for f80/f82/F83
05-27-2019, 09:41 AM | #5 |
209
Rep 314
if your a racer ( constantly pushing the revs in the 7000+ rpm range.. go with a heavier viscosity...if not stick with your basic lite weight oils....of course exceptions do apply to cold or hot climates
Headhunter.M3197.50 |
05-27-2019, 10:14 AM | #6 | |
32
Rep 49
(summing up the debates): LL01 should protect better, but LL04 means low ahs/SAPS and (thus) less carbon deposits on the valves. I have used LL01 Mobil 1 0-40w for 7 years/50,000 miles in a N52 engine. No wear and no oil consumption. The engine purred like new. Now I am using LL01 BMW M Twin Power Turbo 0-40w oil. BMW wanted to use 0-30w LL04 but I didn't let them. Brought my own oil when the run in inspection was done. |
05-27-2019, 10:25 AM | #7 |
21117
Rep 20,741
Drives: 2021 911 turbo
The principal recommended oil viscosity for the S55 has always been either 0W30 or 0W40 depending on which company was BMW’s primary supplier (Castrol or Penzoil).
5W30 is mentioned as an acceptable alternative. 5W30 is the primary recommended oil viscosity for non-M turbo engines and is readily available at dealers (often in bulk). It is used by most dealers to save cost under the free maintenance program on M cars. I always insist on them using either 0W30 or 0W40.
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
05-27-2019, 02:13 PM | #8 | ||
4998
Rep 6,863
05-27-2019, 02:35 PM | #9 |
On the road to serfdom
1392
Rep 673
Drives: 2018 F80 M3 DCT, 2019 Raptor
I use what BMW specifies for the F80, which is LL-01FE 0W-30.
"God bless our troops...Especially our snipers.”
SYT_Shadow11487.00 |
05-30-2019, 10:19 AM | #12 |
330
Rep 984
A 0w40 oil needs to find the right balance of viscosity. Some 0w40 oils are way too thick such as redline 0w40 and may cause crank hub issues. Some 0w40 oils are too thin and won't protect the engine well at high stresses.
I believe the oils with the right balance of viscosity and are excellent quality synthetics are as follows in ascending order: Shell Helix 0w40 (HTHS of 4.0) Pennzoil Ultra Euro Platinum 0w40 Valvoline Synpower 0w40 Castrol Edge Titanium Professional 0w40 |
JustAnothaM4883.50 |
05-30-2019, 12:31 PM | #13 |
3274
Rep 6,723
Haven’t we gone round and round on what oil to use? This can’t be a NEW poll idea?
tpreston03318.50 |
11-02-2019, 06:37 PM | #14 |
Just Building My M4 Track Car
216
Rep 863
Drives: 15’ M4 Alpine
I live in tennessee it gets cold in the winter and also look at 95 everyday in summer and probably 15-30 degrees in winter. what do you think I should switch to?
I've been told by a bmw mechanic liqui moly is the way to go. was gonna go with 0-40w what do you all think? I push my car pretty hard but not all time. |
11-03-2019, 11:44 AM | #15 |
32
Rep 89
If you don't track your car just stick with oem or any certified oil. I personally use amsoil 5w40 classic euro blend for all my cars and I track them all. They have a higher flash point for track use and I found it to burn less than motul when I had it in my 991.
11-03-2019, 12:09 PM | #16 | |
Racecar Driver
1288
Rep 1,955
Drives: BMW M4
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
11-03-2019, 02:03 PM | #17 | |
216
Rep 863
Also I’ve been burning oil like crazy the last two oil changes I had to throw 1 quart 1000 miles before the service due date. I was at minimum both times. I push the car hard tho I mean everytime I get into it manual mode sport/sport plus and pushing it to its limits. |
behindthen0thing839.50 |
11-03-2019, 02:04 PM | #18 | |
241
Rep 792
11-03-2019, 04:09 PM | #20 | |
Racecar Driver
1288
Rep 1,955
Drives: BMW M4
N1rve
gatorfast4997.50 |
11-04-2019, 05:56 AM | #21 |
142
Rep 931
My dealer put only 0W40 in the M turbo models
Italy
BMW F82 M4 Black MHD CS Map - GTS DKG - Navi -Performance Brake RSL1 Pads - USB - DivX-DVD - Bluetooth - VoiceControl - Connect - Apps - Online - H&K - TrafficInfo - SpLimInfo - WhiteMerino- PDC - Cam - Adaptive Led - Antitheft - CP Steering- Performance ST - Adaptive CP Setup - GarageDoorOpen - Pipercross - Stock Exhaust - Mdrivers Pack - 437M Wheels
Alpine_F82215.50 |
11-05-2019, 10:13 AM | #22 |
1558
Rep 2,505
2019 M2 Competition- October 2, 2018 ED
2011 BMW M3 Sedan Alpine White Picked up via ED 9/27/2011 & Redelivered 11/23/2011 **SOLD** |
