GetBMWParts
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Engine / Drivetrain / Exhaust / Bolt-ons / Tuning
      05-24-2019, 02:47 PM   #1
ssgm1x
ssgm1x's Avatar
419
Drives: 2020 M340i & 2018 M3
Black spot on spark plugs.
Can anyone tell me why these plugs have a black spot on them ?
2018 F80 M3 with NGK 97506 plugs that are only 1-2 months old running full E85 (measured E80)
2020 BMW M340ix Dravit Grey
2018 BMW M3 Alpine White
      05-25-2019, 04:34 PM   #2
Fast4d
267
Drives: 325
what's the gap on them?
SAFE-GUARD tire/wheel/windshield/paint protection is a FRAUD! do not waste your money!
      05-25-2019, 04:42 PM   #3
ssgm1x
ssgm1x's Avatar
419
.021 NGK 97506 running E85. About 1 month old.
      05-25-2019, 09:03 PM   #4
ShoNufff
Who's da masta?
ShoNufff's Avatar
Drives: M4
Should be running .018 on e85
      05-26-2019, 03:23 PM   #5
ssgm1x
ssgm1x's Avatar
419
Not needed, but if I had upgraded my turbos and was pushing over 30psi of boost I would definitely gap down to .018, but with my stock turbos at 24.5psi of boost it is not needed.
Zero issues with gap. I Was just curious if anyone knew what these Black marks were.
I read it may be normal and the black mark is where the fuel/air ratio mixture is entering the cylinder and hitting that spot on the plug.
https://forums.24hoursoflemons.com/v...c.php?id=15480
      05-26-2019, 11:51 PM   #6
Shadow2
Shadow2's Avatar
Drives: '16 MG F80 M3
Did you look at your stock ones before you put in those 97506's? My stock ones that were running the OTS e30 map, looked the same, black mark on side. I think its just where the flame front ignites, nothing to worry about, as long as the electrodes look good. I'm running the same as you now, 97506 @.021. Haven't pulled any to look at them, but the car is stroooooong.....
      05-27-2019, 06:28 PM   #7
ssgm1x
ssgm1x's Avatar
419
Stock plugs were on 93Oct unfortunately. I agree with your analysis though.
I also believe that's the spot that is looking at the intake valve. It's hot and the fuel hit that spot and tars or carbons up before the plug sparks.
Running E85 is amazing. I Don't want to go back to 93Octane.
Ditch that E30 Map and get a Custom E85 Map. It's amazing!!!!!
      05-29-2019, 07:29 AM   #8
Shadow2
Shadow2's Avatar
I misspoke, I had been running full e85 for at least 2-3 days on the stock plugs before I switched over to the colder NGK's, but they still looked the same. Yeah I love e85, I've been told its a good idea to run a tank of 93 through her ocassionally, I guess it cleans out the fuel system injectors filters etc. First thing I noticed was how smelly gasoline is, horrible, felt almost nauseous for a min while I re-acclimated to the smell of burnt dino-juice
      10-22-2019, 10:18 AM   #9
coldfish
76
Drives: Alpine White 2018 M3 F80
I used NGK 97506 for a while and they look exactly the same as yours, with only 3000km on them. I have changed them back to stock plug.
Check this up: http://4secondsflat.com/Spark_plug_reading.html
This occurs for two reasons, excessive idling or rich idle condition leaving heavy soot deposits. These deposits will burn and create excessive porcelain temps causing the glass to melt usually resulting in a down track popping through the exhaust..
You will usually see splotchy deposits on the plugs after the run, either green or yellow in color and of course the tell tale shiny glaze. This glazing of the porcelain actually becomes a conductor and the spark will jump from the electrode to the porcelain resulting is a very weak small if any spark. The porcelain should always have a chalky or dull finish.
f80post
