05-23-2019, 10:53 AM | #1 |
419
Rep 771
Oem Gutted DP vs Aftermarket Catless DP
Will OEM Gutted Downpipes yield me the same benefits as purchasing an aftermarket Catless Downpipe ?
Will they flow the same? Or do aftermarket flow better? I ask because I just picked up a set for cheap. I like that the Oem are double walled with Heat Shields and have Perfect fitment but am curious if these Oem Gutted will yield me the same benefits as aftermarket ones. Anyone have any experience running both ?
2020 BMW M340ix Dravit Grey
2018 BMW M3 Alpine White |
05-23-2019, 10:50 PM | #2 | |
29
Rep 149
Would also love to know the answer to this. |
05-24-2019, 12:16 AM | #3 | |
74
Rep 478
I couldn't tell the difference between both. The shape is different obviously. Stock cats are flatter in shape if you've seen it. Given that I'm on stock turbo, I don't think the gutted stock cats will be restrictive.
2013 E92 M3 ZCP
2014 F06 M6 GC 2017 F80 M3 ZCP |
ssgm1x418.50 |
05-24-2019, 01:31 AM | #4 | |
Rep 21
05-24-2019, 04:46 AM | #5 | |
74
Rep 478
I uninstalled the VSRF and drove around on my unmodified Stock DP while waiting for Stock DP to be gutted. I'm usually not sensitive to power increments but I can feel revs are a bit lazy or slower from about 5000 rpm onwards on the unmodified Stock DP. When on VSRF and unmodded Stock DP, my JB4 was on Map 2 so no changes there. Just make sure your mechanic gut the cats as clean as possible so that the inside is smooth to reduce turbulence or restrictions. Edit: I'm not sure if the cops in Sydney issue defects notice like they do in Perth. If the idea is to pass inspections, make sure you know the which way the DPs are facing before you mark out where you want to cut your DP. This is to ensure you don't cut the DP where the welds will be very visible should they want to put your car on a hoist to see.
2013 E92 M3 ZCP
2014 F06 M6 GC 2017 F80 M3 ZCP Last edited by M3 Pilot; 05-24-2019 at 04:57 AM.. |
05-24-2019, 05:21 AM | #6 | |
758
Rep 1,336
Previous Rides: 13' 135i, 08' 130i, 03' HKS Turbo'd 350z, Modded GC8 WRX, NA MX5
05-24-2019, 07:38 AM | #7 | |
27
Rep 64
Some states utilize OBDII testing to confirm 'readiness' monitors are set at emissions inspections, whereas the more Nazi-esque states utilize sniffers and/or visual inspections to confirm the presence of cats. |
05-24-2019, 07:41 AM | #8 |
758
Rep 1,336
I should of been clearer. I have seen this in Sydney. Not sure about other states in AU
05-24-2019, 08:19 AM | #9 | |
27
Rep 64
I've been trying to find out what it is on a state basis in Australia just for the sake of contributing to the thread, but it's so vague and there's not as many people trying to say "fuck off" to to catalytic converters down there as opposed to here! |
05-24-2019, 07:46 PM | #10 |
419
Rep 771
Luckily My car is not due for inspection for another 4 years since Car is New...
