05-22-2019, 04:52 PM | #1 |
Rep 13
Dual Front-Mounted Air Intakes
Hey everyone,
I've slowly been planning out and putting together resources and parts for my F82 "Milk M4n" build, but I've come across a bit of an issue. For the longest time, I've wanted to install a dual front-mounted air intakes from either VRSF (https://www.vr-speed.com/vrsf-front-...0-f82-s55.html) or from RK Tunes (https://www.rktunes.com/products/f8x...r-intakes-2014) or from where ever else, and I've seen tons of Bimmers running around with these things installed. I've also heard some critics say that it's the easiest way to hydro lock your engine since it would suck in rainwater or whatever else into the engine. Is this true? And if so, is there a way around this? I currently live in California, but we've been getting rain for quite some time here in LA. Any and all help would be greatly appreciated!! |
05-22-2019, 05:00 PM | #2 | |
1194
Rep 3,670
RK Tunes, Max PSI, RK Autowerke, or MSR for Front mounts |
05-22-2019, 05:10 PM | #3 |
2889
Rep 2,147
I took mine off for the reason you stated. Just didn't want to risk it.
I bought SSR intakes with wire mesh filters. They sounded great, fitment was fine, and no CEL or other issues besides a jumpy cold start idle. I took them off because I was paranoid driving in the rain or through dust. The other style filters where you need to lubricate do a better job filtering, but other owners have had issues with the oil getting on MAF sensor and throwing CEL. Neither situation is worth compromising for me, so I just went back to stock and get on it all the time now |
05-22-2019, 08:17 PM | #5 | |
646
Rep 1,336
The sound in the summer tho |
05-22-2019, 09:26 PM | #6 |
1582
Rep 1,976
Is this with all intakes? This jumpy cold start? I’m looking for a set but now im second guessing myself.
05-22-2019, 10:44 PM | #7 | |
646
Rep 1,336
It seems like all aluminum intakes have the same issues. K&N and other oiled filters don't play nice with the MAF. Dual front intakes don't seem to fit without modification. Eventuri and Dinan are both beautiful but gains are questionable. End of the day the SSR I can remove and reinstall in less than half an hour twice a year. For the sound it makes it's worth it for me. |
05-23-2019, 08:16 AM | #8 |
11
Rep 76
I have the Agency Power Front mount intakes. I enjoy the sound of them. I have driven the car in torrential rain, warm weather, and 40 degree weather with no issues. The only "issue" I experience with cold starts is the RPM is about 100RPM higher for maybe 30 seconds then lowers to the regular idle speed. No lumpy idle, no stalling, none of that. I would recommend them, no regrets here.
05-23-2019, 08:41 AM | #9 | |
33
Rep 135
Drives: 2015 BMW M4
05-23-2019, 08:59 AM | #10 |
121
Rep 254
Yes they do get wet. I'm running the VRSF front mounts, and generally love them, but I do get paranoid as shit whenever it rains, drive slow, put car into comfort so turbos don't spool as much. etc... Plus they get crazy dirty, mine have been on the car for 2 months, DD, they were bright blue, now they are dark grayish black, nasty.
05-23-2019, 11:19 AM | #11 |
550
Rep 949
The problem with the front mount intakes is those longer tubes add more intake restriction so while you might get a little more sound in the front of the car there is a performance trade off with them. They are also harder to install but I think the water intake risks are over hyped.
For full disclosure we carry the Phoenix Race and BMS Elite S55 intakes. |
05-23-2019, 11:35 AM | #12 | |
1194
Rep 3,670
05-23-2019, 11:57 AM | #13 |
2712
Rep 2,371
I've got the Max PSI front mounts. Water concerns are overhyped; you would have to more or less submerse the front end to pull sufficient water in. Don't be an idiot, and do max speed runs when it's raining hard (for peace of mind), but seriously, these water concerns are overhyped.
That said, there is little data that shows that front mounts increase HP/torque. If I had to do it over again, I wouldn't have bothered.
2015 Black Sapphire Metallic 6MT M4
05-23-2019, 05:06 PM | #14 | |
Some random guy
292
Rep 312
For a practical exercise to prove the point, walk around all day breathing through a snorkel (in effect creating a longer trachea) and see if it is any more difficult. Or, you could look up and trust the Hagen-Poiseuille Law that proves it.
05-23-2019, 07:15 PM | #15 | |
1582
Rep 1,976
For those worried about water, when you see those 4x4s with those snorkels, wouldn’t those be more prone to water than the front mount? |
05-24-2019, 05:10 PM | #16 | |
Rep 13
05-24-2019, 05:13 PM | #17 | |
1582
Rep 1,976
05-24-2019, 05:19 PM | #18 |
2712
Rep 2,371
05-24-2019, 05:26 PM | #19 | |
Some random guy
292
Rep 312
Again, it may not be (probably isn't) of any real-world significance given the relatively short distance added.
05-24-2019, 06:17 PM | #20 |
1582
Rep 1,976
05-24-2019, 07:13 PM | #21 |
550
Rep 949
No I'm not in the intake business so don't have data to post but I know the testing has been done. To relocate to the front and maintain a similar flow to say BMS' design that retains the factory airboxes you'd have to go up to 3.5" piping which doesn't fit very well.
05-24-2019, 07:33 PM | #22 | |
2712
Rep 2,371
As I said in another post, it hasn't been a problem, but I doubt there are any gains. Probably wouldn't do it again, if I was starting from scratch. The benefits are that the dual filters in front look semi cool, and the engine bay is a lot more open. |
